10-02-2022, 07:05 AM   #1
K3 iii menu question: viewing histogram and focus peaking
On my KP, you can’t display the histogram while focus peaking is enabled. it’s a mystery why, but on a retired model “it is what it is”. Great I said, if I can do that on the K3iii there’s one more reason to upgrade (yes, I’m compiling a list, with reasons on one side and dollars on the other)
I was surprised that this limit is still there (pg 64 of the manual), unless maybe it’s been fixed in subsequent firmware updates?
Does anyone have thoughts (or actual reasons even) on why these two functions seem to be mutually exclusive?
10-02-2022, 09:11 AM - 1 Like   #2
My guess … the camera analyses what's on the screen for the histogram … any focus peaking would skew the histogram … pure guesswork, would be happy to know better
Hint :- if you set up Focus Peaking as an option on the control panel you can switch from one to the other fairly promptly
10-02-2022, 09:51 AM   #3
The histogram and focus peaking are also mutually exclusive on the K-3 III, at least with the current firmware. My guess is that they did it sinply to remove clutter.
10-02-2022, 01:22 PM   #4
AfterPentax Mark II's Avatar
Or maybe because they changed the way focus peaking works with the KP and K-3 Mark III? With the older K-3 Mark II and my K-01 I could push down the exposure button and focus and focus peaking (and histogram of course) worked, both in AF and MF. But with the KP and the K-3 Mark III I can only enjoy focus peaking as long as I do not push the exposure button when using MF. As soon as I push the exposure button focus peaking is switched off. So the lightmeter does not work when using focus peaking is possible in MF, hence no histogram possible. That makes a little bit sense. But in AF?
Focus peaking prevails, if you have activated histogram and overexposure warning and then activate focus peaking, histogram and overexposure warning are automatically switched off. Maybe it is a way to reduce power consumption? Or maybe protection to overheating the sensor? Your guess is as good as mine.
10-02-2022, 04:51 PM   #5
ramseybuckeye's Avatar
I would guess they are using some component, circuit, or process that does not multi task. Just a guess.
10-02-2022, 08:16 PM   #6
Larrymc's Avatar
QuoteOriginally posted by rvandenbrink Quote
Well if you compile a list there will always be a reason why you won't buy the Mk III. To me that is a futile exercise.
10-03-2022, 06:00 PM   #7
QuoteOriginally posted by Larrymc Quote
I’m hoping that if I delay long enough I’ll be “forced” to buy the next model. The next purchase is a 100mm macro, then a new body sometime next year
aps-c, dslr, k-3 iii, k-3 mark 3, k3 iii menu, reasons
How can I get easy access to focus peaking and a histogram in LV? phb49 Pentax K-3 III 8 12-27-2023 08:37 AM
K3 iii Live view and focus peaking compared to K3 speagles2 Pentax K-3 III 17 09-29-2021 10:21 AM
K3-III menu on the K1? brainwave Pentax DSLR Discussion 5 09-28-2021 07:58 AM
Focus Peaking/Focus Peaking During Video? snake Pentax K-3 & K-3 II 11 10-16-2013 12:44 PM
Difference between focus-peaking and focus-assist DaveInPA Pentax Q 3 02-10-2013 09:39 AM
All times are GMT -7. The time now is 02:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
