Originally posted by Pete R
But this prompts me to ask a question of the experts: does swapping settings from BOXes 6-10 in and out of the five User Modes work for you?
I've tried three or four times and it always goes wrong: I lose the settings from the User Mode that were originally there, and since they are more important to me, I've stopped trying to use the other five, even though I would find them handy if I could make it work. If anyone has the procedure exactly, or has spotted a pitfall, I'd be very pleased to hear about it.
I too am a bit puzzled about how to work with Box 6–10. As you note, moving (for example) box 6 settings to the box 5 user mode dial position clobbers the settings that were previously saved in position 5. And with no apparent way to restore them except for painstakingly recreating all the selected settings.
My expectation of how Box 6-10
should behave is that they are selectable via a menu operation, just not via the mode dial. I can understand how that might cause confusion as it would be possible to have the mode dial set to ie. user mode 3 while having user mode 7 actually loaded. But the practical result would be no different than if you individual customized some settings while in user mode 3, in that it would presumedly restore the position 3 settings (depending on your settings) when the camera is power cycled or when the mode dial is rotated to another position. Alternately, one of the function buttons could be set as a "shift" key that caused dial rotation to select User settings 6-10 as the dial is rotated through position 1-5 while holding the button.
My K-5 had a single User Mode position on the mode dial, and one could load one of 5 saved user settings by selecting that position on the mode dial and then selecting User Mode 1-5 from a menu via the rear e-dial. So another options would have been to have 1-5 directly selectable on the dial, and then an additional single dial position for 6-10 selected by menu.
As it is now, my workaround is to store an extra copy of the settings from position 5 in box 6. Then I can load any saved settings from boxes 7–10 into dial position 5 to use them, but later restore by loading box 6 into position 5.
EDIT to add: c.a.m's great idea of adding [Recall User Mode Setting] to the Control Panel which then allows loading any of boxes 1–10 into the current user mode physical dial position via selection with the rear e-dial!
Read more at:
https://www.pentaxforums.com/forums/210-pentax-k-3-iii/429995-k-3-iii-how-di...#ixzz7p4X1qwTz
