10-18-2022, 09:26 AM   #1
Perfessor5646's Avatar
K3 MK3 status screen flickers and goes black
After activating the shutter, The status screen on on of my K3-3s will flicker on and off for second or two then go black. When I go to preview the shot just taken it sometimes displays the image for a second, reverts back to status screen then goes black again. The camera does not power off and in Live View the screen functions normally. In fact when it does go back I can put it in Live View mode and switch back to OV mode and things will function normally until I trip the shutter again.
The camera is out of warranty and using FW v1.0.
10-18-2022, 09:34 AM   #2
UncleVanya's Avatar
Sounds like your status screen is set to off. On the k3 and KP pressing info a couple of times gives the option to turn status screw off (or on).
10-18-2022, 09:40 AM - 1 Like   #3
Make sure there's no piece of lint or anything else in the way of the eye-sensor under the eyepiece. Probably not it, but worth checking.
EDIT; Is there a reason you've been avoiding firmware updates? They have all contributed performance enhancement and bug fixes in addition to some added features. It's entirely possible that a firmware update makes things right with the display.
10-18-2022, 10:29 AM - 1 Like   #4
Kobie's Avatar
QuoteOriginally posted by gatorguy Quote
You beat me to it. Was going to mention the same thing.
10-18-2022, 10:36 AM   #5
I had similar symptoms with the screen flickering or not working at all … it was all down to the eye sensor under the viewfinder.
Cleaning it made no difference so I ended up totally disabling it in the menus … I don't miss it
If you're having problems accessing the menus, work in LiveView for any changes you want to make … the sensor isn't used in LiveView!
I'll agree with the desirability of making firmware updates, my K-3iii is certainly more stable these days than when it was new
10-18-2022, 11:46 AM   #6
Only have an iPad Pro. No iMac or PC. Im not especially computer literate therefore not comfortable attempting something that might really mess things up.
10-18-2022, 12:14 PM - 1 Like   #7
MarkJerling's Avatar
With any luck there's another local member who can help you with a firmware update.
10-18-2022, 01:27 PM   #8
Well, I reset the settings to the defaults then changed the ones I knew I knew I wanted changed and now it seems to work normally again. Apparently I inadvertently changed some setting and caused the issue. Thanks for the help.
10-18-2022, 04:18 PM   #9
sorry, how did you restore with black screen? In livewiew?
aps-c, camera, dslr, k-3 iii, k-3 mark 3, k3 mk3 status, mk3 status screen, mode, screen, shutter, status, status screen flickers, view
The K3 Mk3, tested by Amateur Photographer Robot camera Pentax K-3 III 38 08-03-2021 12:22 PM
K3 Mk3 Movie Mode bpcarlson Pentax K-3 III 2 07-30-2021 03:47 AM
K3 Mk3 and wireless flash Spock Pentax K-3 III 5 05-18-2021 02:59 PM
Pentax K7 LCD Screen flickers and ghosting redeleon Pentax DSLR Discussion 10 04-28-2019 02:23 PM
K3 back LCD flickers realitarian Pentax K-3 & K-3 II 7 08-06-2015 11:55 PM
All times are GMT -7. The time now is 12:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
