Originally posted by DAKS
On a K-3 III, can the AF201 FG flash work as a master to a AF540FGZII slave?
I currently have the original K-3 and am ready to upgrade to the K-3 III, but I do use the flash on the K3 as a master, so wondering what configuration could replace that.
thanks
David,
I don't think so David. There does not seem to be any way to set the AF201 to operate in Master or controller function when using P-TTL exposures.
You would be able to use it in Manual exposure mode (Full or 1/4), and by setting your AF540FGZII to Slave mode 2 (dumb slave), have the latter fire when it "sees" the 201 fire. You may find this limiting as the 201 has only two settings, Full and 1/4 and the 540 while having a much wider range of manual outputs is confined to full stops..... Full 1/2 1/4 etc.
A more flexible solution would be to buy another 540 unit, or depending on your requirements go down the road of radio triggers ?
