Show Printable Version 8 Likes Search this Thread
11-08-2022, 08:13 AM   #1
K-3iii ISO sensitivity setting
Out of interest, on the K-3iii, within the 'Exposure Setting' menu, 'ISO Sensitivity Setting' section, the 'Min. Shutter Speed Op.', ISO Auto with Min. Speed' and 'Minimum Shutter Speed' are greyed out and cannot be adjusted.
Can anyone advise what function(s) are these linked to, to prevent them being utilised. My guess is a link to a program function. As I don't use program functions, I don't have intimate knowledge in this area.
Looking forward to your replies.
11-08-2022, 08:26 AM   #2
UncleVanya's Avatar
QuoteOriginally posted by Robert N Quote
What mode is this in where they are grayed out?
11-08-2022, 09:59 AM   #3
Many thanks for the reply. The greyed-out functions are in that state for all mode settings. The camera functions perfectly well as far as I believe, I am just curious what influences this group of functions.
11-08-2022, 10:10 AM   #4
Should be settable in Sv mode?
11-08-2022, 10:16 AM   #5
QuoteOriginally posted by Michaelina2 Quote
See K-3III Operating Manual, pp57...
Cheers... M
Hmmm … tells you what it should do, not under what conditions you can actually change things (my options are greyed out as well!)
Me too
QuoteOriginally posted by mstahulak Quote
Nope … unless there's some other factor to consider !!
11-08-2022, 10:30 AM   #6
QuoteOriginally posted by kypfer Quote
Me too
They are enabled without a lens mounted in Sv mode (at least for me)…? But that is weird.
11-08-2022, 10:36 AM   #7
There are certain areas of the manual where additional explanation is required and this seems to be one of them. One explanation maybe these functions were originally placed in the menu, but in practice not deployed.
11-08-2022, 10:38 AM   #8
Ha ha … hadn't tried it without a lens
It's also available with an "M" lens fitted, so possibly something to do with the clever capabilities of using non-"A" lenses in a/e modes.
Now just got to figure out what it's good for … I wonder if it's covered in the K-3iii ebook?
11-08-2022, 10:41 AM   #9
W412ren's Avatar
Had a quick look on mine. With an M series lens fitted these settings are available in Av mode but greyed out in Tv mode which I think makes sense.
Will have to investigate further
Edit - just seen @kypfer ‘s reply above :-)
11-08-2022, 12:27 PM - 1 Like   #10
You may want to check the "Highlight" or "Shadow" correction options to see if they may possibly be related to other settings that you are trying to access. If you have one or both of them set, they may be already using designated min or max settings. The manual may go further into how the settings may be affected in the way you have mentioned.
11-08-2022, 01:34 PM - 1 Like   #11
AfterPentax Mark II's Avatar
As far as I know it only works if Auto ISO is enabled. It is the same in the older K-3 II, but there it is directly coupled with enabling Auto ISO, but on the new one you have more options to make it more precise and to your liking.
11-08-2022, 06:24 PM   #12
Mikesul's Avatar
That makes sense. But it does not seem to work in TAV which is also a kind of Auto ISO.
11-09-2022, 02:19 AM   #13
If we look at the instruction 17 on page 11 of the manual, it discusses setting auto ISO with the green button. When auto ISO is enabled this does allow adjustment of the functions discussed in my original query. Adjusting the ISO again returns it again to the manual mode. As in the past I have only used manual ISO settings, with Tav being my primary floating ISO mode. Hence the functions discussed have always been greyed-out. Hopefully the mystery is solved.
Update - I have been the above auto ISO procedure for a range of modes and my findings are below:
Sv - no change to e-dial operation
Tv - Rear e-dial changes ISO and aperture
Av - Rear e-dial changes ISO and aperture
Tav - No change in e-dial operation
M - Rear e-dial changes ISO and shutter speed - aperture remains static
B - Rear wheel changes ISO only
11-13-2022, 06:02 PM - 1 Like   #14
In TAv mode, the shutter speed is specified with the dials, not by the camera. Therefore, the shutter speed settings are disabled in the ISO Sensitivity Setting panel.
11-14-2022, 12:50 AM - 1 Like   #15
The potential problem with a list like this is that the K-3iii, moreso than any other Pentax camera, is very configurable, so these options are only valid if the camera is set up exactly the same
aps-c, dslr, functions, iso, k-3 iii, k-3 mark 3, k-3iii, k-3iii iso sensitivity, program, sensitivity, settings., shutter
K-3iii Native ISO MikeStnly Pentax K-3 III 23 01-05-2023 07:41 PM
K-3iii vs a7iii high iso. And the winner is... jhaji Pentax K-3 III 13 04-26-2021 09:01 AM
Does setting the ISO/sensitivity range work in Movie Mode? BrianStanding Video Recording and Processing 8 03-13-2012 09:19 AM
ISO Sensitivity Steps Tom Woj Pentax K-r 5 02-28-2012 08:06 AM
puzzled about auto sensitivity setting Andrew Crouch Pentax K-5 & K-5 II 3 02-25-2012 10:20 PM
All times are GMT -7. The time now is 04:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
