Originally posted by simon_199 As far as I understand the relevant plot on PhotonstoPhotos to assess that aspect of the ISO behavior should be the one linked below.
Both K-3 and K-1 seem to switch in full ISO increments, even though the largely ISO-invariant sensors doesn't show it as clearly as the 5DM2 with its nice plateaus in this graph. The K-1 II and KP have a very wavy 'photographic dynamic range' in the higher ISO range, in full EV periods, indicating that also the noise reduction parameters seem to be optimized at full increments. The K3-III does seem to be more fine-tuned. An additional complication for Pentax might be that while the nominal ISO increments are equally spaced by 1/3 EV, the actual implementation, as recently discussed, better matches -0.3 EV / +0.3 EV around the full ISO stops in terms of captured raw values, likely also contributing to the overall waviness - photostophotons uses the nominal ISO.
