Originally posted by StigVidar
I mention this because my own experience is to never trust that an adjustment is correct and final.
Keep things practical. Personally I took pictures of a house (with dented bricks) and trees at the background at a distance of some 25 metres. I took them at 0, -1, -2, -3, -4 and looked which pictures looked sharpest at 100% (bricks and trees). Then I took pictures at 0, +1, +2, +3, +4 and same procedure as before. My DA20-40mm Ltd on a KP was sharpest at -2. Then I took several test pictures to see whether the pictures were really sharp at -2. They were and so this is a correct setting. My DA12-24mm needed +1 on a K-3 and my DA17-70mm needed -2 on a KP. When you are in doubt which picture is sharpest, just use 0.
But when I use my DA17-70mm on my K-3ii, no fine adjustment is needed.
Just three on my ten lenses needed some fine adjustment.
