Is the program line the same on both cameras? Ibis or SR? Backfocus/frontfocus can be avoided with liveview? ...
Thie program line could yield quite different shutter and aperture settings for the same image in the same circumstances. Landscape setting is more prone to handheld shake than the sports program line setting, night mode will drive up ISO (and noise), as an example.... there is also a program line to maximise MTF, optimal lens sharpness.. etc...
What lens are you using? If it is old(er) film era lens, it might be outresolved by the higher Mpixel of sensor and then the way you crop plays a role. It is a bit strange both ’leaves pics’ show almost same pixel count yet are coming from 16 and 24 mpixel camera , cropping or resizing might influence.
If you attach orignal pictures when posting on forum, they will be reduced in size, indeed less good for details (we got the point from above png cutouts) , but the exif information will be visible , revealing what parameters the camera’s used like lens, shutter and aperture, iso and more.... unfortunately the above images in png format have lost even this basic info. This site will show basic exif info, if we download there are over 100 parameters in exif that we can study...(yes, some forum members will go this deep...)
Since you compare cameras, we have to make sure they use similar settings. Unfortunately there are quite some settings, some deep in menu, on the (newer) camera's that can raise differences in such comparison ( but contribute fortunately to the picture quality if set correctly
). If you forget about one, it can drive you crazy... hence post original raw or jpg format with exif (file out of camera, no processing), not png without info.
Just noted : The first two charts are shot at f4, 1/8 or 1/13 and iso 640. This jpg format is already more usefull but GIMP erased most details in EXIF.
This are dangerous slow shutter speeds, even on tripod it might suffer from mirror and shutter shake, might be camera dependant. Most lenses are sharper at f7...f11 , so I think you need more light for such a chart test? 1/250 or faster, f6.7 and iso100 or 400 are a good minimum target.
