Originally posted by Mccsiz I should have my new HD Pentax D FA* 50mm F1.4 SDM AW some time next week. If anyone has any pointers about how to adapt this lens to my K3 iii crop camera, I would appreciate it.
Um, what do you mean "how to adapt"? You put the lens on your camera, turn on the latter, make sure that the AF switch on the lens is set to "AF", and just prepare to be amazed - it should work straight away as is. About the finest 75mm-equivalent-FOV short telephoto lens you can put on your K-3 III, I'd wager.
Okay, cockiness aside, the thing is that given that backwards compatibility is such a thing in Pentaxland, FF and APS-C models share the same K Mount (which made its debut in 1975, although it has gone through a number of iterations since then). Therefore, despite covering the FF sensor and being a bit of overkill for the smaller APS-C sensor, the DFA*50 works perfectly on your K-3 III. It will just give you a short-telephoto-equivalent field of view, instead of the wider, standard one on the FF K-1. Which is because the K-3 III only uses the center and inner borders of the image circle that the lens projects onto the sensor, but not the outer borders and corners, which are "cropped out" (scare quotes because this is not done electronically/softwarewise, as it would be on the K-1 in when set to Crop Mode, but because the APS-C sensor is simply too small to record those areas). Hope I'm making sense.
Reason: Explanation added.
