Originally posted by Sandy Hancock Unless you have a *large* studio, I really think 85mm will prove a bit long for all but head and shoulder portraits.
The DFA* 50/1.4 will do the job nicely, while maintaining a nice connection between you and your models. If you need a wider option, the Sigma 35/1.4 Art has similar optical qualities.
^^^^^^this^^^^^^^
To do a full length of a 6' tall person, the camera would need to be over 20' from the subject, and that would be an exceptionally tight crop.
This was shot with the DA70 Ltd, so quite a bit shorter than 85mm, but was shot on the APS-C format. The model was quite tall, I recall she was 5' 10" or thereabouts.
I was across the hall and in another room to get enough distance, probably I was back at least 15 feet. She didn't have room to stand in that alcove.
This was shot with the 77mm Ltd, this time in a studio setting, again on the APS-C format. The model was quite a bit shorter, IIRC, she was around 5'5" tall, and I was back somewhere around 20'.
I think the first image would have been a problem for an 85mm focal length due to space restrictions, but the second would have been quite doable simple because I had a large room to shoot in.
Keep this in mind when choosing equipment to purchase. It would be a terrible shame to spend big coin on a DFA*85/1.4 and then not be able to use it the way you want because your room isn't big enough.
I no longer have access to a large shooting room, so even with the K1 I'm not able to use my 85mm for full length portraits unless I'm doing them outdoors.
