Originally posted by jersey No adapter, formatted in camera. Checked contacts, reformatted in camera again. Never checked sectors for validity, but it should not have an impact on writing with flash memory.
PS - yes. I know, I rarely shot series, it happens in all fps modes, single too. And it is almost never few seconds, it just stops until I realize it and remove/reinsert battery.
There is an indicator ’card access lamp’ next , right to the 4way dial/buttons on back of camera.
As long it is on/flashing, one should not:
- Open card door or remove cards
- remove battery
As this interrupts the card writing process, you end up with broken links in file structure on memory card, which can confuse camera sw... reformat is solution.
There are several reasons it might take time before camera writes to card, and they add up if more than one activ, requiring more camera processing time:
- raw+ jpg takes longer than one only
- series or bracketing or composites ...(works as multiplier, filling buffer with unprocessed images)
- lens distortion correction by camera (pentax lenses)
- custom image mode bright, natural, portrait,....
- digital filters high contrast, monochrome,...
- hdr , pixel shift
Some will also delay showing the image on back display, remaining black without wait indication.
On my k-3II, I stopped using digital filter high contrast (even while it did a good job on mirror lenses with lousy lens contrast)
As it locked camera for several seconds after 3...5 birds pictures, there was always next bird.... and camera was not ready.
Postprocessing became more convenient for contrast correction.
