Originally posted by AfterPentax Mark II Usually the item to be charged is not capable to receive higher W than what is specified. In this case the K-3 Mark III has a security circuit included to prevent damage to the camera in case of using a wrong charger. The security circuit corrects the charger to deliver the W specified. My experience with using the "wrong" higher powered chargers is that it takes longer than with the charger provided with the gear. If you have this expensive camera I would not put in danger of an overload. Moreover, in such cases warranty might be void.
Have a look at page 129 of the manual indicating the use of the dedicated power adapater.
By default, USB Power Delivery (USB-PD) chargers (like the one I have currently) start with the base max charge of 2.5W and only provider more than that if the device actually asks for more.
This is to prevent what you are mentioning of too much power. Older devices don't know how to ask the charger for more so they are protected.
My question basically is, Does the K3mIII use USB-PD or not?
I should have asked it that way.
---------- Post added 04-01-23 at 01:59 PM ----------
So the first charge using my 18w USB-PD charger took less than 1 hour to fully charge (from basically empty according to the camera battery indicator) I will need to try this again with the stock charger.
Any others with different chargers have different times?
