Originally posted by pedroin That's an interesting advice...Sadly, there is no way that I can hold a Pentax camera here in Lima Peru. The market is full of Sonys and Canons. And I move to Florida in July, so my best chance is getting a Pentax online. Thank you for your insight.
Why not wait until you move to Florida and buy your new camera once you get there? You may find a friendly shop that will be able to give you excellent recommendations, since they live there and know the local conditions really well. Also, if you buy in the US, you're have proper warranty coverage if anything turns out to need attention. This is another good reason to buy from a shop. First, by buying from a local shop, you'd be helping to ensure that the shop is still there when you need them, or want to check out how something feels to use before you buy it. For one example, when I bought a K-5 back in 2011, right out of the box neither control wheel worked. You could turn them, but nothing happened. I have no idea why I didn't notice that when I picked up the camera, but I blame it on the excitement of getting my first DSLR. Replacing the camera was just a matter of going back to the shop and getting another camera off the shelf and I was good to go the same day, with no postal delays or hassles to deal with.
Second, you'll have a warranty that's valid in the US, and warranty coverage can be a big help if anything goes wrong, as in the example above. Modern DSLRS, and even "simpler" cameras like mirrorless and P&S (Point &Shoot) models are very complex devices, so it's no surprise when one of the hundred or so features doesn't work as it should. I've had my K-3 III for a few months, but I still haven't checked out its connectivity features yet. I've had my K-3 since 2014, but the intervalometer function is yet to be used or even tested, for just one example.
Finally, July is not far away, but it still leaves time to add to your savings if you're putting away some money every month. This will make your purchasing decisions easier when the time comes.
So, which camera and which lens? I agree with a number of members that the K-3 III and 18-135 is the best kit to start out with. Since you shoot RAW, I assume that you have quite a bit of experience and don't want a camera that you'll outgrow. The K-3 III is one camera you will not outgrow. As for the DA 18-135 lens, it has a very wide zoom range, is very light and compact, and is quite affordable. While it does not have a wide aperture, this is less important when it's matched with the K-3 III, because that camera can give you clean images even at fairly high ISO settings. I won't give upper limits, because your acceptable image quality and mine may not be the same. With the K-3 III, though, 3200-6400 ISO seem like "medium" speeds, with much more to explore at the higher settings.
Oddly enough, I recommend not buying any DA* lenses, at least not for a while. They make such sharp pictures possible that you'll soon be spoiled and want to shoot with nothing else, regardless of their greater size, weight, and cost relative to everyday lenses.
Good luck and happy shooting!
