Originally posted by thix2112 I have DXO Pure Raw 3 (which has a bit more adjustment options than v2). I think DXO works better on K3iii DNGs than Adobe AI, particularly when you set DXO Pure Raw to the DeepPrime setting (not the DeepPrime XD setting as mentioned earlier).
DXO will work directly within Lightroom as an external process and you can set up how/where the DXO raw file places its final output file inside of Lightroom.
Tom
I have tried with the "new" DPreview raw samples at lower ISO and the observations I made a few months ago are unchanged. Actually DPXD works perfectly up to iso800. Perfectly="as advertised", i.e. less or same amount of residual noise in the smoother or out of focus areas, and improved details. At iso 1600 things start to break down and XD is significantly worse than DP standard. Artifacts appear in the detailed areas and the noise in OOF areas actually increases, and there is no amount of fiddling around with settings that makes it better. Actually as the ISO get higher, the result seems to become increasingly unresponsive to any slider for DPXD. The transition is not abrupt, that is between the full stops 800 and 1600 it transitions gradually from "working as advertised" to "broken". At ISO12800 DPXD is unusable, results are garbage. DP standard is acceptable, but below expectations (i.e. below what I get out of similar apsc sensors, including the KP). I guess it could be fixed but I can't estimate the amount of man-hours needed....
DP standard is quite good up to iso 4000-5000.
To sum it up what I do with my K3iii files is:
- up to ISO800-1000: DPXD, great results
- 1000-5000: DP with "noise model" slider turned down a few notches, results slightly below expectations, but satisfactory
- 5000-25600: DP, quality of the results is highly variable, depends on the image and specific portions of the same image might turn out good or bad. XD is basically unusable in this range
All in all it's more than workable. If one does most of his shooting in the iso 5000 to 25600 range, maybe there's something wrong
Since XD seems basically bugged (high-iso not only results are poor , but the sliders don't do anything, it is clearly abnormal) I still believe that it is a type of software issue that could be fixed and unlock even more potential.
