A couple of weeks back I took my recently-acquired Belarussian BeLOMO AGAT-18K half-frame camera out for its first session...
The joy of getting out and about for some photography was quickly tempered by my realisation that - despite its "new / old stock" condition - the viewfinder was dusty and very hazy internally, making it difficult and not at all pleasurable to use. Quite how the internal glass surfaces got so bad, I have no idea, as the camera's lens is immaculate.
Today, I decided to see if I could do something about it. After separating the two case halves, I looked at the viewfinder area and found a kind of "trap-door", secured by a couple of small screws:
After removing these screws and gently prying up the door, the viewfinder assembly lifted out - almost in one piece:
I say "almost" in one piece, as the thick front lens group remained loose in the camera, but this slid out easily enough.
I used a rocket blower to get rid of any dust and debris, wrapped a small length of a Zeiss optical wet wipe around a wooden cocktail stick, then used this to gently clean the surfaces, borders and corners of the viewfinder elements. Just a few minutes work, and everything looked spotlessly clean. Fitting the viewfinder assembly and front element back into the camera was easy enough. Getting the small screws back in was trickier than removing them. The screws are self tapping and secure directly into the plastic casing (the camera is almost entirely plastic, save for the glass lens and viewfinder, and metal film guide / pressure plate). Added to that, the lip of the case means that the screwdriver is at an angle to the screw heads. Trying to get the screws back into the original threads without "biting" and creating new ones was frustrating to say the least, not helped by less-than-rock-steady hands. It must have taken me 8 - 10 attempts for each screw... but I got there in the end.
Now, looking through the viewfinder into a bright room light, there's no sign of any dust, debris or haze. She's crystal clear and ready for a day's shooting - and
this time it should be FUN
