I do not pretend to be a qualified camera technician, nor a lens expert, so lenses I'll try and fix tend to be simple.
And I don't do that many... usually one or two here or there... I am not Ismael
I've also noticed a number of threads going on in parts of the forum, talking about fungus and what it looks like...
So, these are from this week... three lenses, three examples of fungus...
And yes, I do live in a humid environment, and these lenses all came from near where I am, so they have probably spent the past 50 years in a hot, humid mess... so if you live in the UAE or most of Australia, this is not for you...
Lens #1, Nikkor 135mm f2.8 (Non-AI)
This lens was filthy all over. The front element was dirty, with a little fungus on the outside and a lot of scuffing, explained by the lack of cap or filter
Everyone should put protective filters on their lenses so when I take them off they are clean...
The lens was also covered in sticky yuck. Maybe it had been taped at one point? wrapped in cheese?
The rear element was the big mess, though... this was on the inside of the rear element...
I'll note the yellow blobs aren't fungus... they're reflections of the overhead light at a very different color temperature than the LED flashlight shining up from under the lens.
Yuck. And I have no idea what those lumps in the clumps of fungus are... small bugs that died and fed the fungus? I don't want to know...
Whatever this was, it cleaned off really well, with no real obvious evidence afterwards. The lens is still full of "old lens dust", weird specks of stuff, and everything you expect from 50 years of life... In this case the Nikon habit of putting all the optics in a separate set of things from the mechanism made this a lot easier.
Lens #2 was another Nikkor... this time a Micro 55mm f3.5...
Some of this was fungus, but a lot of it was dust, dirt, and fuzz. It cleaned brilliantly, and it was all on the outside, so I didn't even need to open up the lens.
Still, it looks horrible...
Lens #3 is a Vivitar 100mm f2.8 soft focus lens.
Well, I'm calling it a soft focus lens because it has maybe four elements and one of them looked like this:
I haven't seen anything quite like that since a 1990s-vintage screen saver that did fractals...
I worked hard to clean this out, and the fungus is now gone, but its remains, well, remain...
That's the assembled lens, and if you look, you can still see the trails from the fungus. It isn't as bad as it was, and if you aren't shining a light through it, you may not even see it at all, but it is still there...
I'm really looking forward to seeing what that does to the images, but I really wish I had a pristine copy of this lens to compare with -- somehow I doubt it was super-sharp when it was new...
Anyway, a few fungal experiences this week to remind everyone to keep our lenses dry.
And put caps on your lenses if you're going to put them in bags!
-Eric
