08-25-2022, 02:16 PM   #1
What aperture is my Super-Takumar 55 f2.0 really?...
I just picked up a Super-Takumar 55mm f2.0... it is version 1 of the Super-Tak described here, with the fine ribs and backwards aperture ring:
SMC/Super-/Auto-Takumar 55mm F2 Reviews - M42 Screwmount Normal Primes - Pentax Lens Reviews & Lens Database
The weird thing is that it has an extra click past f2.0... and the aperture actually moves when I do that, so the aperture is actually wide open at this unlabeled click past f2
The lens is labeled as a F2, and it sure looks like a f2... which also apparently looks just like a f1.8 apart from the labeling...
I want to say I've heard that the f2 is just the f1.8 with a baffle in the optical path, but that doesn't seem to be the case here, since I can see the aperture blades close down.
And I can't see a catalog number anywhere on it like I've seen on some lenses (I think that came later).
Is this just a case of Pentax being lazy?
"Well, you can buy this S1a with a 1/500 shutter speed and the 50mm f2.0 lens, but really it will still shoot at 1/1000 and f1.8, we just didn't want to change the hardware..."
-Eric
08-25-2022, 03:53 PM - 1 Like   #2
Argos's Avatar
QuoteOriginally posted by TwoUptons Quote
-Eric
Your lens basically is a 1.8/55 with a built-in limiter ring.
08-25-2022, 03:56 PM   #3
MarkJerling's Avatar
Now, that's interesting Eric! I think I have one of those, much check mine! (Unless, of course, mine's a later one.)
08-26-2022, 03:13 AM   #4
So here's a really bad iPhone shot of the lens set at f2. You can see the aperture blades just inside the ring.
I did notice it is a vastly earlier serial number than the one Argos posted...
I guess I need to see what the photos look like... though it's not the cleanest lens I've ever seen, it is close to 60 years old...
-Eric
08-26-2022, 07:41 AM   #5
Argos's Avatar
-Eric
The Super-Takumar 1:2/55 mm [Model I] was produced between 1962 - 1965, but only the first series had the counter clock-wise rotating aperture ring. I think your lens shows traces of wear and/or play in the aperture mechanism. The aperture blades should not be visible at f/2. Later series have a clock-wise rotating aperture ring that does not move beyond f/2. The aperture ring has ribbings in both cases. I have written a book that deals with things like this.
08-26-2022, 08:01 AM   #6
QuoteOriginally posted by Argos Quote
Maybe that's all it is... more play over the intervening 60 years...
But the fact it clicks into place below f2 is the part that made me think it's weird... is it the same mechanism as the f1.8 just without the label (and with the limiter)?
And that's obviously something that changed over the intervening years, so maybe this is just one of those weird early-series things that was fixed later...
-Eric
08-26-2022, 08:06 AM   #7
Argos's Avatar
-Eric
Yes, the f/1.8 and the f/2 are virtually identical. The only difference is the limiter ring. This must have been a commercial decision to sell the f/1.8 at a higher price, although the f/2 may have been more expensive tot produce.
08-26-2022, 08:48 AM   #8
So it really is the perfect lens for the H1a
-Eric
08-27-2022, 02:55 AM   #9
I wanted to ask for a reference but looking at your other posts made it clear that this is the famous Gerjan speaking… The book is highly recommended!
08-28-2022, 01:06 AM   #10
Argos's Avatar
QuoteOriginally posted by wkraus Quote
Correct, it's me, Gerjan van Oosten, as you can see in my profile.
09-18-2022, 06:55 AM - 2 Likes   #11
Well, whatever aperture it is, it seems to work just fine
Though this obviously is not a test wide open...
-Eric
09-18-2022, 12:19 PM   #12
Argos's Avatar
-Eric
Looking good!
09-18-2022, 01:44 PM   #13
-Eric
It is definitely not cheepnis inside. I tested my two copies of the Super-Takumar 1:1.8/55 (S/N 1211… and 3486…) and the 1:2/55 (S/N 4885…) and the latter was the best performing.
aperture, camera, click, f1.8, f2, f2.0, lens, pentax, super-takumar, super-takumar 55 f2.0, vintage
Auto Aperture FAQ - changing aperture using lenses without aperture ring angerdan Film SLRs and Compact Film Cameras 11 03-11-2022 02:03 PM
Are fixed aperture zoom really fixed aperture ? lotech Pentax SLR Lens Discussion 11 01-05-2022 01:20 PM
Nature One Really,Really,Really Red Rose. :) Tonytee Post Your Photos! 7 08-13-2021 10:14 PM
All times are GMT -7. The time now is 05:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
