Hello,
Like in a hot pepper eating competition, start mild and work your way up the hotness.
1- Start with simple distilled water and a cotton swab. You'll be surprised how effective that can be.
2- If needed, then move up to non-acetone nail polish remover in a cotton swab. Just enough without flooding it. *EDIT* As mentioned below, you can also use 99% IPA (Isopropyl Alcohol)
3- Next step, BRASSO metal polish or similar (Blue Magic, Mothers, etc.). I've had good experience with BRASSO but again, a small dab in a cotton swab and work a small area.
Word of caution: chrome plated brass can vary from nuclear resistant tough to barely adequate thin. You need to always be on the lookout for brassing (removing the plating and showing the base metal).
This was severely pitted and corroded.
4- If it declares war, you can step up to heavier guns: Abrasive cleaners.
5- And if it is a matter of mutual annihilation apocalyptical war then:
But the first 2 or 3 would do
Hope this helps.
This is just my experience, but I'm sure there are other suggestions as well.
Thanks,
Ismael
