Hello,
The Kodak Brownie Hawkeye is one of the most popular cameras of the mid 20th century. The great Arthur Crapsey designed this camera. He also designed many great Kodak cameras from the 40's until the 70's. This camera was produced from 1949 until 1961. The only main change was the addition of flash support in late 1950. Made of bakelite, a popular material of the era, this camera was very successful. Today, it is arguably the most popular 620 camera out there and enjoys a cult following. It is very basic: single shutter speed (about 1/40s) and Bulb. No aperture control. No focusing. That's it. Just shoot and advance. The resulting image is square format of 2
1/
4 inches or about 6cm on each side. One of the reasons why this camera is so popular is that you can use 120 film without re-spooling. However, the take up spool has to be 620. A 120 spool will not fit as take up.
My specimen:
This camera is very popular and easy to find. While still affordable, prices are not what they used to be. So I got this broken and abused Flash model sample basically for the price of shipping.
Left for dead, it has seen far better days.
The biggest issue among many others is this big chunk of body missing. Light leak anyone?
Bakelite is a very brittle material.
By the way, the datecode is
CMRO which means the last 4 weeks of 1956. This camera will be 66 years old next month (December 2022)!
Every single part needs help.
AHHH!!!! The venerable rotary shutter! By the time this one was made, the base concept was already over 70 years old!
Cleaned and lubed, ready for at least 66 more years!
Let's fix the missing chunks of body.
The plan of attack is reconstructive surgery using epoxy sculpting compound. Keep in mind many of these pics are larger than actual size.
First, a small strip of aluminum tape as backing.
Sculpt to rough shape
Cut a precise strip of thin aluminum sheet, bend to shape. I was going to use brass but aluminum worked like a charm.
Adjust as needed
Maniacally test fit every move
Technically this should do it as is.
Continue test fitting constantly while shaping the part
A few days go by carefully shaping the part while taking extra care to prevent sanding dust and water to get into the shutter
When doing bodywork, you look with your fingers. Don't trust what you see. Trust what you feel. Is it smooth? Do you still feel the transition?
A few more days go by and your fingertips say you are ready to paint.
Attempting to match the original bakelite finish will be a lengthy nighmare. I decided to mask and paint it flat black so it will stand out on close inspection and not look like a lame attempt to match the original finish.
Forgot to take a picture of the inside prior to assembly but it was carefully painted light sucking flat black.
TA-DAH!!! Oh wait! Everything else is still disassembled. At this point it becomes a "regular" restoration
Presenting for your approval my "Ready to be tested hopefully soon", "NEW"
1956 Kodak Brownie Hawkeye!
A little lithium grease under the opening latch and it may be smoother now than when it left the factory
The bright viewfinder is another reason for its popularity
Badges of honor: Lots of scratches, blemishes and hairline cracks in the body are reminders of a tough past. If this camera could talk!
Biggest problem now? Fingerprints!
Also bakelite is a dust magnet.
Can't wait to test it!
I hope you like it and approve this Special Rescue Operation.
Thanks,
Ismael
