Originally posted by boriscleto
If it is focused to 3 feet there should be enough room to unscrew the cap. Perhaps the lens was mounted incorrectly?
Maybe so? I don't know enough to say.
If it helps, the serial # is 470138. And here's another view:
Originally posted by TwoUptons
I think my most common problem has been an idler gear screw that didn't want to come off...
Is the C3 the one with a rangefinder that will clunk back almost into place if the lens is mounted wrong?
Once you get it off, you can make sure it goes back on right, though... and then check it with some scotch tape on the film plane and the door off...
-Eric
Thanks for the tip, Eric. This is not only my first C3, it's also my first rangefinder. So this is all new to me.
I'm not certain what I should be seeing through the viewfinder, but there's a split image which can be aligned when I turn the rangefinder dial or the lens focus ring.
To be honest, I'd rather use the lens on a digital camera than shoot film with it. But I won't risk damaging the Argus just to try to get the lens off. I'd rather give it back to Goodwill whence it came.
