I found a Kodak No 2 Folding Autographic in an antique store and tried running an old expired roll of 620 film through it. The film was fogged.
The bellows on that camera were in pretty rough shape with some separation at the seam where the fabric overlaps on the under side of the bellows.
So I searched Ebay and found one with the original owner manual. I used the main camera/bellows from that one and joined it up with the film back from the first one I bought because it was in better shape and still had the stylus.
120 film will fit and wind in this camera on the 120 spools so I ran off a test roll. The attached pic is a negative scan at different aperture settings developed in D76 for 9 minutes. You can see that there was a light leak that fogged the film in the lower right area. This was from the window on the back where you would write your info with the stylus on the original Autographic film.
Yesterday I modified the film back by adding a layer of 1mm light seal foam on the inside covering over the autographic window opening to eliminate the light leak. I have a roll of 120 loaded up and I'm shooting some photos to see if I got rid of the leaks.
Shutter speeds are 1/25, B, T, and 1/50. I measured the speed at 1/50 and my tester reported back 1/38. I'm shooting this roll at this speed and using a light meter to help calculate f stops.
The aperture on this model is not marked in f numbers. It reads 1 NEARVIEW PORTRAIT, 2 AVERAGE VIEW, 3 DISTANT VIEW, 4 CLOUDS MARINE
I'm guessing from the size of the iris in relation to lens opening that these correlate to f/16, 8, 5.6 and 4.
The viewfinder is quite small and hard to see in full daylight so I designed and 3D printed a nifty little hood for it that friction fits on top. (makes it look a bit like a steam locomotive) I plan on making a second version with a magnifying lens in the top portion.
It's a neat little camera. It fit's easily in a pocket when folded up and has two tripod mounts. I find it easier to shoot with if I install a small travel tripod on it as a steady counterweight.
Once I expose this roll I'll post pics in this thread.
More info on this camera can be found here:
Autographic - Camera-wiki.org - The free camera encyclopedia
