I have a Godox Lux senior with integrated Li battery, this is semi automatic flash (via sensor in flash, not pTTL) or manual . Recently acquired, looks OK after first, basic testing. It is the slightly bigger (but retro-fancier) brother of the junior you mention, it is still small in carrying/transport, but bigger in use due to folded-out reflector.
check here for image
Works on any camera with single contact in hot shoe (or with cable, not tested).
Two minor remarks:
- The manual is basic, but the device is easy to use if you ever worked with older flashes. You need to understand guide number and aperture settings etc... to understand the dial on flash. The manual is not for beginners, new to such a flash.
- Charging with USB-c but not on fast, high power one. No idea why, my phone charges on both, the godox only on slower one. But still quick enough...
I have also an older AAA battery powered small 850 pTTL flash of godox, works also fine on my pentax (needs 5 pins in hotshoe).
I am an occasional flash shooter, wanted smaller simple, cheap flash, and Godox works for me.... I have now one for my vintage and one for my digital pTTL camera.
