Originally posted by lotech As far as I understand the PC cable only has 2 contacts, which simply act as electrical switch that short/close circuit to trigger the flash, and the cable is fixed to the flash no need to plug in, so I don't know how it can carry 'control signal' to the flash which trigger to use hotshoe or PC, unless there's a switch on the flash to select.
Some cables between the camera and flash (usually called "sync cords") are entirely detachable and some are fixed to the flash. In the case of detachable ones, there is often a microswitch inside the flashgun socket that detects if the sync cord is plugged in, and if it is plugged in the contacts in the foot are electrically isolated. It is like the loudspeaker of a portable radio being disconnected when you plug an earphone cable in.
In the case of non-detachable sync cords, a common arrangement was that they had a slot/groove to stow them when not in use, as they would be when the flashgun was being used in a camera hot shoe. The flashgun foot contacts were only made electrically live when the sync cord was in its slot, and otherwise were dead when the cord was pulled out to connect to the camera PC socket. The picture below is an example ("Fig 42"): the foot contacts lead up
only to a PC socket in the flash body (visible just above the cross-head screw in the foot). When stowed in its slot the cord plugs into this socket and makes the foot contacts live, and when not stowed (as in the photo) the contacts are dead.
Originally posted by titrisol Not necessarily, many "universal" flashes (Inlcuding Metz, Sunpak, Vivitar, Achiever, etc) used to have a detachable cable with a small plug that looked like the earphones plug.
Indeed, there was a large range of plugs, and not only of audio jack type - and even those could be 2.5mm, 3.5mm or something else, and of different lengths. Some makers (eg Sunpak) often used a two, three or more pronged plug, and by the 1990's they were using multi-core sync cords with a plug that slid into the camera hotshoe at one end and had a multi-pin plug at the flashgun end, to carry the proliferation of signals that flash units were using by then. Here is a selection of cords ("Fig 40") :
