03-02-2024, 11:31 AM - 1 Like   #1
Adapted Nikkor 50mm f/2.8 Enlarger Lens
Used an M42-PK helicoid and an M39 - M42 ring. Seems it will be quite good for macro, once I figure out the lighting.
03-02-2024, 11:40 AM - 1 Like   #2
Wheatfield's Avatar
Enlarger lenses make really good macro lenses since they are pretty much flat field macro lenses.
One does need some way of focusing them though. A bellows is an ideal solution, a helicoid extension tube combined with fixed tubes can be workable.
03-02-2024, 12:42 PM - 1 Like   #3
titrisol's Avatar
Location: In the most populated state... state of denial
the Nikkor EL 50 is a great lens
In the helicoid or bellows is brilliant
03-02-2024, 04:17 PM - 1 Like   #4
fwwidall's Avatar
QuoteOriginally posted by jawats Quote
The El-Nikkor 50mm F2.8 is regarded as one of the better enlarger lens for macro use. You should have a lot of fun with it. Its good for up to 4X magnification.
Allan Walls has a good video on its use over on his informative YouTube channel - you might want to check it out.
03-03-2024, 12:53 PM   #5
I'll try this with my extension tubes.
---------- Post added 03-03-24 at 12:55 PM ----------
QuoteOriginally posted by titrisol Quote
Fantastic! I look forward to trying it out on both.
---------- Post added 03-03-24 at 12:56 PM ----------
QuoteOriginally posted by fwwidall Quote
https://www.youtube.com/watch?v=4V0piuv_-70
Thank you for that link!
03-03-2024, 01:21 PM   #6
Wheatfield's Avatar
I use a variety of enlarging lenses on a bellows for macro/ micro photography. At present I have Nikkor lenses in 50mm, 63mm, 80mm and 105mm as well as Fuji 50mm and 80mm lenses. All of them are superb performers.
They can often be acquired for next to nothing at swap meets or second hand camera counters since darkroom work has waned so much over the past couple of decades.
My own journey with this very interesting genre of photography started with close up lenses. I also tried reversing rings that mounted the lens directly on the camera and then as I started getting more glass rings that would mount one lens reversed on another one.
Along the way I bought extension tubes and one day I found a Pentax helicoid tube in a dump bin at my local pusher's store.
The advantage of the ability to move the lens in very small increments compared to the rather gross extensions available in extension tubes cannot be overstated, and that helicoid tube ended up pushing me away from it and I started collecting bellows.
Is the plural of bellows bellows, more bellows, belleese or something else? These are the kind of important questions that keep me awake at night.
Anyway, at last count I have 4 of the things.
Also, if you aren't using a bellows, a macro focusing rail is a really handy thing to have as it allows the camera to be moved in very small increments. A bellows will have this built in.
03-03-2024, 03:44 PM   #7
Excellent! I have an old set of Vivitar bellows than I use with my K-1, and will try it with this for macro. Thank you!
03-03-2024, 04:01 PM   #8
Wheatfield's Avatar
You are welcome.
FWIW, the photo below was shot with the K1 and a Fuji 80mm enlarging lens. This is a focus stack, a technique I find invaluable for close focus work as it allows the lens to be at it's best aperture rather than having to stop down into the diffraction zone for DOF. There are a few soft areas because I didn't do enough exposures.
The flowers are about 7mm across
03-03-2024, 04:18 PM   #9
You are welcome.
I have a couple other enlarger lenses...one Wollensak and...something else (I can't locate in my storage right now). One is 135mm.
03-03-2024, 06:33 PM - 1 Like   #10
Wheatfield's Avatar
I think you'll find that your Nikkor 50mm is going to do a lot of what you want. One of the things I noticed with older enlarger lenses made for large format (your 135 would have been made for 4x5) is that sometimes they weren't as good as the lenses made for smaller formats because they were never worked all that hard.
But don't let this stop you from trying!!!
One of my favourite lenses of all time is an old 300mm large format barrel lens that couldn't produce a very sharp image but was perfect for pictures that involved naked ladies.
This is the nice thing about lenses. Every one of them has a subject. It's up to us to find what it's good at doing.
03-08-2024, 04:40 PM - 1 Like   #11
ChrisPlatt's Avatar
The less common 63mm EL-Nikkor is excellent and often used for macro work.
I tried the 63mm f/2.8 EL-Nikkor lens and it soon became my standard for making 5x7 and 8x10 prints from 35mm negatives.
IMO the slightly longer focal length allows for a more comfortable working height of the enlarger head in the normal range.
Chris
50mm f/2.8 enlarger, camera, enlarger lenses, extension, field macro, helicoid, lens, lenses, macro, macro lenses, nikkor 50mm f/2.8, pm, tubes, vintage
PC-Nikkor 28mm 3.5 shift lens adapted to k-mount sculptor666 Pentax SLR Lens Discussion 7 01-16-2020 06:03 PM
Adapted Nikkor Lens on Pentax K1 - How'd It Do? Fenwoodian Pentax K-1 & K-1 II 5 05-02-2017 09:42 AM
Nikkor 500/4 and Nikkor 300/2.8 sucessfully converted to Pentax K using Leitax mount beholder3 Pentax SLR Lens Discussion 4 07-03-2016 07:05 AM
For Sale - Sold: Nikkor 24mm f/2.8 Ai-s **ADAPTED TO PENTAX** deadwolfbones Sold Items 26 08-04-2011 09:21 AM
For Sale - Sold: Nikkor Ai 105mm f/2.5, adapted to Pentax K-mount (US/CAN) farfisa Sold Items 3 05-06-2010 01:45 PM
All times are GMT -7. The time now is 08:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
