05-16-2010, 04:54 AM   #1
External Hard drive disappeared
I plugged my external hard drive in and loaded it up with 20 gig and now it's just gone! The computer cannot recognise it. Any advice appreciated.
Cheers
05-16-2010, 06:09 AM   #2
Wheatfield's Avatar
If it's a USB, try rebooting the computer with the drive turned on.
Not that this should make a difference.
Also, simply unplug the drive and plug it into a different port, preferably one that is on the computer, not a USB hub.
Or, consider that the drive itself may have failed.
05-16-2010, 06:31 AM   #3
Test it on a different computer (it might be a port failure on yours).
Test it in a different enclosure (might also have a failure).
If this doesn't help, then you're mostly up that particular creek
05-16-2010, 07:12 AM   #4
My 320GB SATA drive in external cabinet with USB interface with Windows XT Pro, needs coaxing -- I've found powering up the drive and letting it run for a few minutes before connecting to computer, then after power cycling the drive while connected to computer, sometimes several times, the computer recognizes the drive which thereafter runs fine no problems. ymmv.
If that doesn't help, next thing to try is open up the external drive cabinet and disconnect/reconnect all of the cables inside. Oxidation preventing operation, on connections carrying low-level signals, gets wiped away.
05-16-2010, 08:36 AM   #5
1,000,000th Poster!
That's my photographic nightmare #1. I always keep copies on at least three different drives. But I just started so it's still manageable. I think everyone here will be rooting for you to save your data, and keeping notes on how you've managed to save it. Let's remain positive!
A few questions.
Not that I can help out much but maybe someone out there knows these newfangled things known as computers much better than I do...as long as they have a bunch of info.
1- Is it on a windows platform or on a Mac, maybe even a linux-based computer? which one?
2- your external drive, whats the type? USB, eSata, Firewire? Can you remove the drive from its enclosure? Is it just a key?
Any info you might have would be good. Otherwise everyone here will be blindly giving suggestions like a shot in the dark.
Good luck!
Flickeroo
05-16-2010, 10:50 AM   #6
Marc Sabatella's Avatar
This isn't really the right forum for questions like this; in fact, it really isn't the right site, period, as it has nothing in particular to do with Pentax or photography in general. But I'm moving it to what seems the closest fit.
05-16-2010, 02:09 PM   #7
philbaum's Avatar
I'm not sure if this relates or not, but i've found thru losing a drive myself that these externally powered external hard drives are VERY sensitive to shock. I had one fall off a coffee table in a hotel room about 12" to a heavily carpeted floor and it was dead. Then I switched to a lightweight slim USB 2 powered laptop external drive (mine is called a Seagate GO drive), its much more durable and will survive that same fall without failing (dumb, i know :-)) They are slower but if you're carrying your laptop with you, much safer to take along. Leave the larger external drives at home in a location that they can't fall from :-(
05-16-2010, 05:27 PM   #8
I do apologise for posting it in the wrong spot, but us photographers need our storage.
The drive connects through usb and this ended up being the problem. Dodgey port.
Anyway, thanks all for the replies.
05-16-2010, 05:53 PM   #9
1,000,000th Poster!
Happy to hear it Carl!
Glad you didn't lose anything.
05-17-2010, 04:03 AM   #10
KJon's Avatar
I'll second the congratulations on your not having lost anything, but there's a lesson in this; if this is your only "backup", you're in a really tenuous position. You need to have multiple bites at your data. Drives and CDs/DVDs fail - burn yourself some multiple copies. I would be devastated if I lost my digital photos. (With film, you at least have the negatives, but if you've scanned and edited them, you will have lost all that time and have to start over).
Best,
Kevin
Last edited by KJon; 05-17-2010 at 05:13 PM. Reason: I may actually learn how to spell (or at least type) my own name.
05-17-2010, 10:51 AM   #11
forensicscientist's Avatar
backups...
Consider having an off-site back-up as well. I keep one copy at my office....just in case.
05-17-2010, 05:12 PM   #12
KJon's Avatar
QuoteOriginally posted by forensicscientist Quote
+1
Best,
Kevin
05-17-2010, 06:25 PM   #13
Well I have everything on DVDs at the moment and this is why I have purchased this drive. I do need to go and get a few hundred prints done also. You know, something to hold
drive, tripod
Help! My external hard drive is not 'acting' up! schmikey Pentax Camera and Field Accessories 1 04-09-2010 08:58 AM
pentax k20d and external hard drive dstar Pentax DSLR Discussion 7 07-07-2009 07:15 AM
External Hard-Drive for $150? Opinions plz :) rdrum76 Pentax Camera and Field Accessories 3 12-23-2008 04:22 PM
Possible to copy from k20d to external hard drive directly dutch Pentax Camera and Field Accessories 5 09-01-2008 10:00 AM
External Hard drive squarerigger General Talk 9 05-20-2007 08:48 PM
All times are GMT -7. The time now is 07:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
