Originally posted by sterretje I have two tripods with tilt/pan head. And both suffer from the same problem / user error.
When I tilt it so a picture is framed correctly and tighten the 'screw', the head tilts forward and therefore the framing changes.
Is there something that I do wrong or is this inherent to tilt/pan tripod heads? Is it the specific head and can it be solved using another tilt/pan head or a ball head?
One of the heads is a Manfrotto 391RC2, the other one is part of a Velbon tripod (CX510?).
Thanks for your advise.
I fear, that is basically inherent to almost any cheap tripod head. The extend varies, but the problem of shifting the camera, when locking down the head is all too common.
So far my Manfrotto 468 ProBall was the head with the slightest shift, but I just got an ArcaSwiss ballhead and hope, that the shift is even less.
Basically the only heads, that don't show any shift are gimbal mounts, because you won't lock them for the shot.
Ben
P.S:: as Phil noted, this problem might be worse with pan/tilt heads. I use only ballheads, so I can't compare.
