Originally posted by steven smith I have a K10d, one of my lens's is Sigma 500mm, the tripod I have is a little shaky for that lense plus the camera. Rather than order blind I thought I would take advantage of prior expierence. thanks.
Which Sigma 500? 50-500 (aka Bigma) or the 500/4.5 prime?
Either way - I'd suggest one of the larger Benros or Induros. Aluminum is a better choice than carbon fiber unless you are hiking a lot with the tripod, since a heavier tripod will lower the CG of the setup.
The Adorama Flashpoint CF tripods appear to be identical to the Benros/Induros.
You'll probably want to look into a gimbal head for your lens. Adorama has one that's much cheaper than the Wimberley units -
FPDG1 Flashpoint Gimbal Head 1 with Quick Release, Supports 15.4 lbs.
I have a Benro C-158n6 carbon fiber unit and love it. It has been replaced with slightly newer models, but if you're not hiking frequntly with the tripod like I do, I'd suggest looking into a 3-section aluminum 2-series or 3-series tripod. Benro part number will likely be something like A-257 or A-357.
