Originally posted by switters I don't want to get into an argument here. There are many other people on the forums that have reported flash exposure problems with the 540 & K10D, so clearly I'm not alone.
Actually what you don't want is to stand alone, to be unique, at the very least to run at the head of the pack. As to the argument, whose arguing? Forums are about discussion,; this is a discussion.
There are a
handful of loud forum citizens who have a problem with virtually every piece of new equipment; and an equal number of groupies who think that whining and band bashing actually improve their own lack of talent and technique. Statistically, these number less than statistical error!
Originally posted by switters What's more, I used my Canon 20D and 430EX nearly every day in e-TTL and manual mode without a single complaint. The exposures were as I expected them to be almost every time.
Stick with things you can understand.
Originally posted by switters Why should I have to go through what you went through to get proper exposures in P-TTL? Frankly I have neither the time nor the inclination. Isn't the whole point of P-TTL to make exposing with flash a whole lot faster and easier than it was in manual, automatic or even TTL modes? And since I was able to get the Canon system figured out in about half a day, why is it unreasonable for me to expect Pentax to work in a similar fashion?
The Pentax is
not philosophically similar to either Canon or Nikon; neither in form or in function. It doesn't lead, it follows the photographer direction. It's very similar to having someone hold your hand while you cross the street VS crossing by yourself.
What I 'went through' has been considered by some to be a normal learning and growing process. As to Canon or Nikon being 'simpler', I repeat "Stick with things you can understand."
Originally posted by switters No, it isn't unreasonable. Pentax simply isn't up to par with Nikon and Canon in their TTL capability. I've seen many complaints both here and on DPReviews. So you can keep your GUFFAW to yourself!
As to unreasonable-that fault is entirely on the side of the whiners and bashers. Like you, they have provided little or no credible evidence, nothing approaching a definitive study and not so much as a testable postulate let alone a full blown hypothesis. No it shouldn't be rocket surgery or brain science, the flash is, after all, a simple device.
Still, I assert, the average person will need to spend more than a couple of hours and a pop more than a few frames to learn it's intricacies. And a whole lot more to qualify such sweeping and banal assertions as yours. Can you provide evidence that you are something extra-ordinary and exempt from my assertion?
Until such a time I will withdraw as there is little to discuss in this thread---moving along, not much here.
See, not a single "Guffaw".
