I first posted this last May, 2009.
It is neither elegant nor refined , but it does the job and is cheap and is very simple to use.
Carrying K100D on a Bicycle and trekking.
I have tried various items for carrying my K100D when bicycling. None were satisfactory.
A handlebar bag had me concerned about vibration on bumpy terrain as did a bag on the rear carrier.
The Op/Tech Camera/Binocular harness was difficult to adjust, awkward to put on, uncomfortable and allowed the camera to hang free and bounce against my chest.
Other devices have components that rest against the chest or back and can be uncomfortably hot and sweaty.
Sometimes the simplest device is the best.
This photo shows my camera hanging around my neck on its usual Op/Tech neck strap adjusted to my preferred working length.
It may be shifted from side to side, higher or lower as one wishes.
It is secured to my body by an inexpensive elasticized belt.
The belt is fully adjustable and quite comfortable and does not produce torrents of sweat in warm weather.
The belt holds the camera securely against my body even when using drop handlebars.
When the camera is in use the belt is not even felt around my chest.
I prefer to put the belt around the camera lens to keep out of the way and prevent it from banging against anything when I am not on my bike. Occasionally I may place the belt across the bottom front of the camera. It will also hold the camera vertically.
On long walks the belt can be used to relieve the weight of the camera on the neck.
When I put on the belt I slide the buckle around to my side so it cannot mar the camera.
The camera may be inserted or removed without opening or further adjusting the belt.
In an emergency the belt can keep my pants up.
The camera in the picture is a Canon T90 with a Sigma 70 to 210 mm lens. It is substantially heavier than my K100D.
The belt came gratis with a pair of slacks but I have seen some for under $5.00 CAN in mens' wear stores.
The frown is the result of trying to get a reasonably framed picture shooting with my K100D down at my hips. It took 8 tries.
Mickey
