Originally posted by Riktar WOW! That is expensive. Maybe I'll just stick to the RF-602 system and deal with swapping the transmitter for the 540 flash, if needed.
I am shooting with a K20d.
Thanks for the info.
Why choose the difficult solution?
K20d has a x-sync socket on the left side of the camera you can connect the RF-602 transmitter to. Using a bit of welcro it's easy to attach the transmitter to the flash or camera body.
By doing this you should be able to use P-TTL for the camera mounted flash, and manual for the remote units.
