Originally posted by Russell-Evans A photo of a clock set to GPS time is the simple solution to time correlation. You have the GPS time captured and you have the time stamp to the second in the EXIF data. Now you can correlate the two. I'm not sure how you are correlating your data to the camera's clock?
I looked at an iblue tracker since you posted it and it looks like a nice solution. I just found the AGL3080 in my price range when I was looking about a year ago and bought it. I just don't have a reason now to spend again for a solution right now, as I'm happy with the performance.
Thank you
Russell
That's the pain-in-the-butt solution to time correlation as it is a manual operation. The easy solution (assuming someone else has already done the automation step for you, which many people have) is:
Pull photo timestamp from EXIF data
Search in GPS tracklog for that time
If there is a large gap in time AND distance between tracklog points, interpolate the position between those points
Put the position associated with that time into the EXIF data
This can be done because any GPS tracklog I have ever seen is timestamped appropriately.
Unlike taking a photo of the GPS clock frequently, all of the above steps can be automated. Software that includes this capability includes:
GeoSetter
digiKam (for Linux/Unix users unless you're hardcore and running KDE for Windows)
I believe Aperture and Lightroom
gpicsync
Plenty more
My workflow is:
Download pictures from SD to a folder
Download the tracklog from my gps datalogger
Go to that folder in digiKam
Choose the GPS Correlator function from digiKam's menus (I may have the exact name wrong)
Load the GPS
Click "Apply"
The only reason to take a picture of the GPS clock would be for the purposes of having a backup method for ensuring that the camera clock was correct. (Compare EXIF to picture content). If you're doing that, you may as well just check the camera clock.
