I bought the
Amod 128MB GPS Photo Tracker - AGL3080 before I received the Droid as a B-day present from my wife. The cost is minimal, $57.95, not counting 4-7% Cashback from Bing.
It uses three AAA batteries, is pretty small, and just works. The size of the GPS is 3.5 inches long, by 1.5 inches wide, by 7/8 of an inch tall. With the three Eneloops AAA batteries installed, the weight is about 3 oz. The mini USB B to USB A cord for connecting the unit to a computer is 18 inches long. You can turn the unit off when not needed so the 15-20 hours of battery life can actually be days or weeks of use depending on the frequency of shooting periods. Switching the unit on again when you are ready to shoot creates a new log file. I don't think there are any limits on the number of files or the number of data points in those files, except for the limits imposed by the 128Mb storage size and the file system.
Turning the unit on and getting tracking only takes a couple of seconds when the satellite data file doesn't need to be replaced. When it does need to be replaced, it like all GPS units, it takes awhile for the file to download. I think the file has to be downloaded ever two months or if the GPS physically makes a large leap when turned off. I'm not sure of the actual distance required, but it seems pretty large.
The 128Mb size sounds small by todays standards, but I choose to log all the data, and set the polling interval to five seconds, which gives something like ten days of data storage on the device. The photo track merging software that came with it I didn't install, as I think it only supported jpegs. I just went directly to another software solution. The unit doesn't have a clock on it, so you have to sync your camera with another clock, which mean setting the clock on the camera before setting out to shoot. The interface is primitive so you set it up and leave it, although the marketing material makes it sound like you can do this on the fly. You can, it just requires understanding the LED codes, but it just wasn't something I wanted to do or needed to do.
Over 15 hours with three standard AAA batteries.
Chipset: SiRF Star III high performance low power GPS receiver IC.
Channels: 20 parallel tracking channels.
Protocol: NEMA 0183 GGA, GSA, GSV, RMC. WAAS/EGNOS
Maximum log points: 1,380,000 (RMC), approximate 3,833 logging hours.
Logging mode: 6 logging modes, can be set in device setting mode.
Interface: USB 2.0 full speed, appears as thumb drive.
The unit next to my "funny" house keys to give an idea about size.
Thank you
Russell
