Originally posted by Lowell Goudge This whole thread should not be about the focusing screen, but the falicy that diagonal focusing targets should be used for FF/BF adjustment.
When looking through the viewfinder, you do not know exactly what the focusing sensor is aimed at. As a result, and perhaps shown here as a worst case, what the OP thought was the focus point, was not, causing misadjustment of the focusing.
The only reliable focusing test is to focus on a target that is perpendicular to the lens axis, a sloped target is simply NOT the way to do things.
Perhaps the focusing screen is not centered, I can't say, but the fact is that the OP was not pointing the camera at what the sensor was considering. If he repeated the test on a flat surface, he would focus correctly.
As for the screen, being off center is a problem, in terms of using it on other AF lenses because the split image will lead you to focus at the center of the split, that is just human nature
Can you expand on this Lowell, I've used the sloping one before and I'm very interested to see what advantages the perpendicular method has, and how it's done ?
