Originally posted by blwnhr So if someone can give me pointers for flash settings, camera settings etc. I'd be very very much obliged.
Adam,
I apologize, I'm not familiar with your flash. Does it do P-TTL? If it does, you may be able to get pretty good results by putting the K10D into aperture-priority (Av) mode, setting the ISO to Auto, and set the flash to P-TTL. With a K10D and the Pentax 540 flash unit, that combination of settings produces very reliable results. Remember, when you're shooting with the flash, most of the time, the shutter speed doesn't really matter. Not always, but most of the time.
Now, if you start using bounce flash, you may have to compensate a bit, by upping the power of the flash half a stop or a whole stop. If you're simply stepping farther away from the subject, and the flash is pointed more or less at the subject, the camera and the flash will take care of everything for you, because they can figure out how far you are from the subject, and that allows them to calculate the right amount of light to put out. But if you are bouncing the flash, well, the camera can't correctly figure out how far the light has to travel.
Bouncing the flash takes some practice and in real life, doesn't seem to be completely reliable, as real-life candid shooting involves bounce surfaces whose properties are somewhat unpredictable, and besides, the distances are hard to calculate in your head when you're busy shooting. I get decent results most of the time even with the flash unit attached to the camera and pointed right at the subject -- but with the flash dialed down slightly. A flash diffuser is supposed to help, but I don't use one yet.
I would recommend a little practice at home before the big party. I think flash is a whole area for graduate study in itself -- but the basics are not too difficult. P-TTL, Av mode and auto ISO is sort of the point-and-shoot mode for flash photography.
Will
