06-28-2010, 01:53 AM   #1
sajah's Avatar
K20D grip terminal rubber bung
Hi,
When I bought my (used) K20D it was together with the grip. So, only much later when I wanted to used the K20D without grip that I realize, the grip terminal doesn't have its rubber bung anymore
This is the small black rubber with the word "PULL" on it (see attached picture). Its purpose is to cover the grip terminal when no grip is attached. I suppose this rubber bung is part of weather-sealing feature of K20D. I'm not sure, can my camera get damaged if some liquid enters the unprotected grip terminal and making contact with the pins?
I'm having problem getting the right keyword to search this rubber thingie on the internet. Do some shops actually sell this part which I presume, got lost often? And any suggestions, what keyword I should use to find them.
All helps and comments are much appreciated. TIA.
06-28-2010, 05:52 AM   #2
It would probably be easiest to get a hold of a local/national pentax rep to obtain a replacement. That said, looking at the contact area it is similar to my weather-sealed handheld gps - and those contacts are exposed, no covering. Nonetheless, you are probably best off getting a replacement, Pentax is probably a good place to start!
06-28-2010, 09:21 AM   #3
imtheguy's Avatar
The PentaxImaging store sells them directly. This one is show as for the K10 but I don't know it its the same as K20D. Might take a reply from someone who has both. Yes, its $9.95 for a $0.25 piece of rubber but solves the problem.
PentaxWebstore Bottom Cap K10D
06-28-2010, 09:41 AM - 1 Like   #4
Juat a thought
Make sure it is not on the grip.
There is a place on the top side of the grip (mating surface for bottom of camera) where this piece is placed while the grip is on the camera. It is a blank hole intended for this purpose.
And yes, the K10D and K20D are the same piece. I know because I used the grip for both and put the rubber piece from both in the holder on the grip referenced above. Same piece.
woof!
06-28-2010, 09:46 AM   #5
Ratmagiclady's Avatar
Not to state the obvious, but just in case you're unaware:
Did you look for the bung on the part of the grip that normally faces the underside of the camera? That's where they're supposed to be stored.
Just in case you hadn't known.
edit: (Oops, crossed posts with Woof. )
06-28-2010, 09:54 AM   #6
sajah's Avatar
QuoteOriginally posted by pxpaulx Quote
QuoteOriginally posted by imtheguy Quote
Thanks! Although Pentax Imaging Store does not ship internationally, googling "Pentax Bottom Cap" gives me a lot of alternatives. And yes I believe the grip for K10D and K20D is the same.
06-28-2010, 09:56 AM   #7
sajah's Avatar
QuoteOriginally posted by Ratmagiclady Quote
Yup I've looked there and it's empty. Apparently the previous owner didn't bother to store it there
06-28-2010, 02:13 PM   #8
QuoteOriginally posted by sajah Quote
Yes, they're the same, incidentally.
07-06-2010, 01:49 PM   #9
filmamigo's Avatar
My K10D (also bought used) was missing the bottom cap. I ordered one through a local camera store (Henrys). It took a couple of weeks and too much money, but is worth it to keep the rain out when you don't have the grip on.
(Now you've reminded me that it's also missing from the bottom of my MZ-S :-)
07-08-2010, 01:56 PM   #10
Senior Moderator
Parallax's Avatar
Just a Small Piece Should Do It.
bung, grip, k20d, keyword, rubber, tripod
Loose rubber grip CGottfried Ask B&H Photo! 4 06-24-2010 10:28 AM
Terminal cover Substitute Pentax Camera and Field Accessories 11 01-15-2010 01:43 PM
Terminal Madness Nowhere Matt Post Your Photos! 1 09-09-2009 02:27 PM
All times are GMT -7. The time now is 03:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
