07-29-2010, 02:52 AM   #1
Ni-MH batteries with TR 3 Power Pack
Hi All,
I've just bought TR 3 Power Pack for my Af540FGz and am looking to power it with Ni-MH batteries. The manual recommends alkalines and states that Ni-Cad should not be used. I have a set of 5,000 mAh Powerex's which are of course, 1.2V.
The TR 3 input is rated at 9V, which is a match for 6x 1.5V alkalines.
I'd like to know whether using the Ni-MHs is OK, and any useful recommendations in their use.
Cheers,
M.
07-29-2010, 07:26 PM   #2
You should use 1.5V batteries! The power pack is trying to convert 9V to 330V, by reducing the voltage, 1.2V per cell, you will have a lower voltage out of the power pack. You have two things going on here, there is not enough voltage for the voltage multipilers to work properly and the flash, IF, it fires will not have enough voltage to fully drive the strobe and will have reduced output and can cause misfires. It is also possible to damage the electronics with the reduced voltages but that will be the luck of the draw.
I too, would like to see a good 1.5V rechargable batterie akin to the Eneloop.
07-30-2010, 08:20 AM   #3
The NiZn batteries are higher voltage, ~1.73V.
Thank you
Russell
07-30-2010, 10:17 PM   #4
QuoteOriginally posted by Jerome Smith Quote
I took the plunge and used the Ni-MH's. Works like a charm! I'm getting around 1 second recycle times for sub full charge bursts.
Interestingly, I've read somewhere that the Powerex's are above 1.4V when fully charged. I don't have the gadgets (or inclination) to measure any of this, but I'm happy enough atm.
Cheers,
M
11-24-2010, 01:19 PM   #5
Malsi's Avatar
Hi,
I've just received the power pack. Is it normal that there isn't anny battery cover (juste the normal case)?
Regards.
Malsi
11-24-2010, 01:41 PM   #6
Eruditass's Avatar
Alkalines actually operate under load at lower voltages than NiMh.
12-10-2010, 01:59 PM   #7
QuoteOriginally posted by Malsi Quote
That's correct!!
alkalines, batteries, ni-mh, pack, power, tr, tripod
TR Power Pack 3 Oscar1 Pentax Camera and Field Accessories 1 02-10-2010 08:57 AM
Power cord for a TR Power Pack 2 Vern Pentax Camera and Field Accessories 4 12-06-2009 08:13 AM
TR-3 power pack and af500ftz reknelb Pentax Camera and Field Accessories 0 02-03-2009 03:38 PM
TR Power Pack III Batteries -- NiMH ??? snostorm Pentax DSLR Discussion 4 10-21-2007 09:03 PM
All times are GMT -7. The time now is 09:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
