The commercial website for Y Strap is here:
Y Strap The Figital Revolution
I ordered mine on July 18th for $25 and received it tonight, July 31st. The Website owner writes that he sews all the Y straps individually to assure quality so i'm not concerned about a slight delay in receiving it.
Here's my observation after carrying my camera around for 1 hour with it.
1. I will never use a neckstrap again. The Y strap is so much more comfortable to walk around with my K20D.
2. The Y strap relies on a large key ring attached to the right neckstrap attachment point on the K20. The large key ring was too large to install on my K20, so i found a smaller keyring to link between the large one on the Y strap and the camera. The website notes this might occur and will provide a smaller ring for the linkage if asked at ordering time. Do yourself a favor and ask for it ahead of time, although smaller ones are easily found in hardware stores or extra key chains around the home.
The R Strap relies on a screw into the tripod mount on the camera, which has come loose for some people, rarely i would guess. (i've also seen an R strap used with a key ring installed to the neck strap connection) No chance of that with a Key ring i'm thinking. Other than that, there is a lot of similarity to the two straps. R Strap includes a shoulder pad plus some storage area for cards and things. Either, i think, would be a great improvement over a neck strap.
3. For larger lenses, i can see how the Y strap width can become a little uncomfortable if its too close to the neck. I put on a Pentax prime lens on my K20 and then it was quite comfortable. I will look for some wider pad for the strap where it crosses the shoulder. All in all a vast improvement over the neck strap, however.
4. See the video on the Y strap website. The camera now rides on the right hip with the lcd window against the jeans. This means its probably a good idea to put some kind of protector on the lcd window
5. One of the things i like about the Y strap is the strap folds down easily when packing the camera away.
I have no financial interest in Y Strap, but for $25, it was a good deal for me.
