Originally posted by jaieger Just wondering: do you lug it around by hand, put it in a large pack, tie it to your ankles, what do you do with em if you're out in the field with one?
I've tried mounting the tripod horizontally, at the bottom or the top of the pack, but doing it that way the tripod seems to get caught on trees or railings so it doesn't work well.
Most packs have some sort of very strong, short haul/carry strap at top-center right between the shoulder straps, perfect for holding a tripod of almost any length. I usually carry a Gitzo 3-section tripod (21" collapsed) with the ballhead already installed, with two or three legs of the tripod dangling through the pack's carrying strap. This keeps the tripod out of the way, and puts the weight right on your shoulders where you can handle it best, yet the tripod is still instantly available without any unbuckling or unclipping. Nice solution while hiking or biking.
Some packs also have a strap down near the bottom, which you can use to keep the tripod legs from swinging around when you walk.
