Sprung the bucks for the Bog-Pod "Q-Stik"; seventy-five bucks on sale right now at Cabela's:
BOGgear BOG-PODŽ Multipurpose Monopod : Cabela's
Here's my initial "review" of the product: Length adjustment is tricky, make sure you read the instructions! The stick is adjustable from about a yard to about two yards. (Plenty of height for picture-taking except for the tallest among us.) Advertised as suitable for a hiking stick, and seems like it would be really good for that - two choices in "feet", and once adjusted, very stable. The hand grip comes wiith a retention strap, and conforms nicely to the hand. Shaft appears to be aluminum, so it does bow a little if you put pressure on it, and would not survive being run over by a truck, still it's lightweight and extremely strong in the vertical dimension. If used within the limits of its design, it should be eminently durable.
It comes with several "switcheroo" attachments and a bag to haul it around in (like, if I needed to haul stuff, I'd really carry the thing in a bag rather than using it for walking support). There is a series of ball-detents in the socket that hold the attachements securely once inserted, and it's just a push-me, pull-you to get 'em on and off. There's a compass embedded in a cushioned hand-grip, a ball-head for photography, a stabilizer bar for use with binoculars, and a rifle-stock rest support. I bought it primarily because of the height and the flexibility provided with all those attachments.
The ball-head is usable and seems pretty much indestructible but not up to the quality standards that one might expect from a "real" one. I tried it out in low-light long-shutter release time mode with good success, including times up to thirty seconds. I had the anti-shake function on, of course, but the result was very good - what was supposed to be in focus was, and what was supposed to be blurry was blurry. The ball head is made with two gaps for tilting a camera up or down, but it's also easy to aim the camera by changing the angle of the whole stick and adjusting the ball head appropriately.
Overall, I think I recommend it; I can see myself hiking on the trails of the Blue Ridge Mountains with that thing.
