Originally posted by Recercare
Is the split/microprism enough to make a significant improvement from the original screen. My slowest lens is F4.
If you primarily use fast lenses, you probably DON'T want the optibrite treatment. Optibrite produces a brighter image, but at the cost of decreased focus accuracy (specifically, increased apparent depth of field) for the matte portion of the screen.
See ("Optibrite or not") at
OptiBrite Brightness Enhancement - KatzEye Optics .
The split prisms/microprisms are much easier and faster to use than the focus confirm light/beep and the standard screen -- but only more accurate if your focus screen is properly calibrated. See various threads here about calibrating the focus screen shim.
