08-20-2010, 03:09 PM   #1
ytterbium's Avatar
DIY clamp "tripod"/mount solution.
Since i could not find a solid clamp mount for reasonable price, that i could get i decided to improvise.
I took the smallest and cheapest clamp tool (2$) and cannibalized head and center column from my old broken tripod. All i had to do was to drill two holes in both pieces and hacksaw part of the center column off.
Thanks tho the cheap materials used in clamp it was very easy.
Here is the result:
Conclusions:
Very cheap and easy to make. Almost easier than to try to acquire a specialized photo clamp.
Clamp pads not optimal for pipes, needs precise placement.
Robust construction, but also heavier than expected.
Pan head not the best for randomly placed column.
Can securely support even medium format TLR.
In future i might shorten the center column and tightening handle, to allow attachment for greater thickness.
Probably ball head should be used.
Maybe the head should be attached to the other end of clamp.
08-20-2010, 03:16 PM   #2
Moderator Emeritus
As long as the head is firmly mounted to the center column, that's stinkin' brilliant. You could take that hiking and clamp to just about anything without having to carry a tripod what is bulkier and longer.
08-20-2010, 03:32 PM   #3
Nice! If the center column were shorter, the clamp would fit around larger object, though.
08-21-2010, 01:39 AM   #4
ytterbium's Avatar
QuoteOriginally posted by civiletti Quote
Yup. I plan to shorten it. I was afraid of cutting off too much, but it looks like i could gain a decent distance without loosing any stability.
08-21-2010, 01:42 AM   #5
TOUGEFC's Avatar
Nice! Great idea mate!
08-21-2010, 01:56 AM   #6
Jools's Avatar
Vey nice.
Harbor Freight... you've got an order.
08-21-2010, 05:17 AM   #7
Ex Finn.'s Avatar
That is great, good idea.
Here is something to consider for those that are less mechanically inclined, cost little more but works great, it has 1/4-20 and 3/8-16 threads on the stud allowing the use of most heads.
http://www.bhphotovideo.com/c/product/5160-REG/Manfrotto_2909_2909_Super_Clamp_with.html
08-21-2010, 08:08 AM   #8
Brilliant.
Thank you
Russell
08-21-2010, 12:07 PM   #9
ytterbium's Avatar
QuoteOriginally posted by Jools Quote
Vey nice.
Good. I'm interested to see with what you will come up. Be sure to let us know.
Btw mine has nuts, both outside and inside of the center column pipe. I wonder if i would cut a slit in the center column, and replace outside nut with a knob-style nut, i could make it variable height.
08-22-2010, 12:03 AM   #10
Lowell Goudge's Avatar
I would be interested to know if you could attach the head to the fixed jaw of the clamp allowing you to eliminate as much of the clamp rod as possible
I like these clamps due to the padded jaws
08-22-2010, 01:56 AM   #11
ytterbium's Avatar
You could simply strap the center column parallel to the fixed arm of the clamp with few hose clamps:
08-22-2010, 10:59 AM   #12
Clamp
I just bought this clamp from B&H. Works GREAT!!
Slik Clamp Head 32 618-021 - B&H Photo Video
You EASILY get your money worth with this. Very sturdy, very adjustable. I'd give it an award if I could.
08-23-2010, 06:39 AM   #13
MRRiley's Avatar
Great DIY project. May have to look around Goodwill for a suitable tripod...
08-23-2010, 09:22 AM   #14
I ha e a monfretto long lens support and the clamp that goes on the tripod leg also doubles as a clamp for a camera if you add a head onto it
08-23-2010, 10:04 AM   #15
ytterbium's Avatar
QuoteOriginally posted by Marcus Quote
Those are nice. I'd rather go with this one:
Ultrapod Ultra Clamp Assembly PD05020 - B&H Photo Video
..unless the shipping price were twice the cost of the item itself.
center, column, head, tripod
DIY Macro Ring Flash for DSLR (Easy/Cheap/Durable) - The "Fring" SF1 Flashes, Lighting, and Studio 17 02-01-2012 07:42 PM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
Helios 44-2 "wobble" and a solution mikeSF Pentax SLR Lens Discussion 14 05-20-2010 10:40 AM
My "perfect" solution to hiking with camera gear bdery Pentax Camera and Field Accessories 20 10-29-2009 05:17 PM
DIY "crackbabies" (lens hacks -- similar to lensbaby product) SF1 General Talk 10 05-06-2009 06:18 AM
All times are GMT -7. The time now is 01:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
