08-23-2010, 09:57 AM   #1
imfinetoday's Avatar
Pentax 540af P-TTL issues
So I've had my flash for a while now, and never had problems until recently: I can't get the P-TTL to work. The first time I noticed the issue, it wouldn't turn off of TTL. Then just the other day I had the flash on my camera, it WAS on P-TTL, then all of a sudden decided to change to TTL, and even go as far as to change the format to 35mm. I'm using a K20 with a Sigma 24/f1.8.
Any thoughts on what's going on?
08-23-2010, 10:16 AM   #2
Perhaps a loose connection when mounted? Try cleaning the contacts.
08-23-2010, 11:36 AM   #3
I agree on checking the contacts. The K20 doesn't even support TTL...
change, flash, p-ttl, tripod, ttl
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
Firmware v1.31 causes wireless P-TTL issues on the K10D? adamfogerty Pentax DSLR Discussion 10 01-12-2011 07:16 AM
P-TTL flash issues Ash Pentax DSLR Discussion 28 02-17-2008 01:54 PM
P-TTL VS TTL.... what is the difference to the average user? slip Pentax DSLR Discussion 16 01-17-2007 12:22 PM
All times are GMT -7. The time now is 11:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
