Originally posted by Lloydy Don't lick the lens, the paint is probably 99% lead and you'll go insane.
What, an insane Pentaxian? Isn't that an oxymoron?
Originally posted by Ikarus I'm having a problem with the Jupiter-9 and the original Pentax adapter on the K-x.
Which J9 version do you have: M39 or M42? My M39 copy, with an ultra-cheap M39-M42 adapter ring glued on, has a wide conductive lens base that yet doesn't short the contacts on my K20D when mounted on a non-flanged adapter. Even two stacked strips of metal tape don't do the job, so I can only use CIF with my J9 when it's mounted on a flanged adapter. But there are no LiveView problems with either cheap adapter I may use on the J9, nor with any other manual lens that *does* short the contacts. So all I can suggest is, try a strip of metal tape on the lens base.
