Originally posted by shellie It sounded like you like that plate, but I notice it's not the one currently on your camera. Did you need a different plate to hook your OP/tech strap to? I want a hand strap for exactly the reasons you stated: to make it easier to grab the camera out of the bag, and to relax my hand while I'm shooting. I like the hand strap in your picture. Sounds like it works great! (Does the plastic clip bother you at all? It looks like it might hit right on the boney part of your hand.) I also like that you can undo the clip quickly if you're wearing gloves.
The reason I don't have it on the camera is the plate on the camera is an L-bracket. I prefer this type of QR plate as I have a tripod with a flex center column, and I have a very light weight tripod that needs the L-bracket to help it be stable in portrait mode. The other reason I don't have it on the camera is that the round QR plate is pretty new to the market and I simply bought other things before I bought it. The film camera I bought the round QR plate for is too old to find a L-bracket for and although an old camera, it is new to me. The round QR plate is as good an option for it as any other QR plate, IMO. I also liked the small size of the plate for the smaller film camera and I just thought it was an interesting idea. I'm pretty happy with it on the film camera.
The clip doesn't bother me now, and it has been too long for me to remember if it did when I first started using it. That said, I don't have much feeling in my hands. I tend to have people tell me I'm bleeding more often than I feel the cut or scrape myself. It could be completely uncomfortable to other people.
The cost of the
Optech clips is around $8-9. I buy the clips with the
Optech backpack straps for the same price on ebay, so if you did it this way, and ended up not liking the clip, you would still have the use of the backpack straps for hiking. This assumes your pack will work with the straps, of coarse. The female clips for the grip/strap I used for the grip/strap are from a used Tamrac neck strap I picked up at a pawn shop. I was just after the clips so it didn't matter about the strap itself. You can find deals on the
Tamrac straps on ebay with the clips I used, but they will cost you another $11 or so.
The actual grip/strap I'm using is a
$4 ebay strap. The padding is pretty comfortable. When you first open the package, they have a pretty strong smell, but after a few days the smell is gone. The smell is actually from the webbing, not the pad part, so I'm not too worried about the smell long term. I went cheap on the grip/strap because I wanted to spend money on the L-bracket instead of the grip/strap. I'm on my second batch of the grips/straps with the reason being on the second round because the first batch just got dirty and adsorbed the sweat off my hands. This makes me think spending more on a nicer grip/strap would be money wasted for me
I use the webbing of the strap in a different way than normal. I cut the slip ring loop off and hot glue a small fold in the end of the webbing. I then thread this through the camera's strap mount where the fold stops the end of the webbing from coming through. The webbing then goes through the pad and then I reuse the slip ring to attach the female clip to the webbing. Looping the webbing around the clip and then taking the end back through the slip ring This puts all the mounting hardware at the bottom of the grip which I found to be more comfortable and made the strap easier to adjust.
I think that's about everything I can say about the grip/strap setup I using. Really, you could just buy the $4 ebay strap just give it a go as is to see if a hand grip/strap is really for you. It all going to be personal preference anyway. That's how I started with my setup. I just added bits to the strap until I was happier with it. It evolved as I used it. You might come up with other ideas that work better, or just not be happy with it at all. Start cheap, and then spend more money if it works for you. The anti Thom Hogan advice.
Thank you
Russell
