Like many of us, I found the
Peter Greggs ABBC ABetterBounceCard for Canon Flash Nikon Flash and Digital Cameras | abbc is abetterbouncecard for canon flash nikon flash and better flash photography website, and I was rather pleased with the result with such a simple thing (some paper, tape, and a bit oftime. Also, like some of us (or many), I build plastic models. Among my supplies are sheet styrene. They come in sheets that are slightly narrower and shorter than a sheet of letter paper. They also come in many thicknesses too. Also they're
white.
Looking at my sheet styrene, all nice and white, and looking at my flimsy bounce card, a light went off in my head (or should I say flashbulb). What if I subsitute sheet styrene for the paper?
After a little experimentation, I have something that works pretty well.
Here's what you need:
1) Sheet styrene, as thin as you can get
2) Silver paint
3) Black paint
4) Masking tape
5) *optional* airbrush (something you'll probably have if you build models).
1) Make a cutout of your bounce card.
2) Tape the card to a wall so that you cover up your white reflecting surface.
3) Paint 1 or two layers of silver paint onto the back of the card.
4) When the layers of sliver paint dries, paint one to two layers of black paint on the card.
5) When everything has dried, simply unstick your card from the wall and use it as you would on your flash.
The idea behind the layers of silver and black paint are simple. The thin styrene is translucent, and the purpose of the silver paint is to simply throw that light that would be wasted forwards towards your subject. The black paint is there so that you don't blind everybody behind you.
Different paints will work better or worse. Tamiya paints, being acyrilic, tend to flake off at certain points where the card flexes around your flash head. Lacquers or enamels may be able to better resist the flaking. The bonus to using styrene and water based acyrilics is that you can simply wash off the paint with the proper solvent (in the case of Tamiya, windex will strip it right off), and then reuse the same piece of plastic over again.
The great part about using styrene, is that you can glue this stuff together quite easily with the proper glues, and the bond will be very strong. You can build pretty much anything you need out of it!
