Originally posted by jbrowning Hello Marc, how are you doing? If I am understanding you right. If I have the head locked down totally then I should have the SR off. If I am rotating the head side to side I should have the SR on. Am I understanding you correctly. Great to hear from you again Marc.
Thanks
Jim
Hi Jim, doing OK and hope all is well!
My statement is made from the reference of being able to move the lens from side to side, but also up/down. However, that's move indicative of a gimbal style head, not a ball head. I am guessing it may be a single pan head, but it's hard to confirm.
That being said, I suspect you'll have some play on the Y axis (up/down), but very little if any on the X axis (horizontal). I'd suggest you try some test shots to see. Otherwise if there is X axis play and it freely moves when not locked down, SR may be a consideration.
Cheers,
Marc
