10-12-2010, 08:54 PM   #1
stantheman's Avatar
AF-540FGZ inconsistent results
I do weddings on a very part-time basis. Since I got the AF-540FGZ, I have thought that the results were inconsistent. Shooting a wedding last weekend, it seemed worse. I would change the aperture or the exposure compensation trying to get a good exposure, and finally get a good picture. This would happen when the background of successive shots did not change, but the exposure would. It got a little embarrassing as I was constantly have to fool with my camera, taking 4 or 5 shots or more, where I would normally have done 2. I haven't looked yet, but I just hope the exposure on unique action shots was within a range that I can correct it.
I use it mounted off-camera, connected to a K20D. I set the camera exposure on manual.
10-12-2010, 08:55 PM   #2
wlachan's Avatar
Set the flash to A instead of P-TTL which is a Pentax embarrassment.
10-13-2010, 07:59 PM   #3
stantheman's Avatar
Thanks for the advice. Is this a problem that is acknowledged by Pentax, or one that users have discovered?
10-13-2010, 08:43 PM   #4
Same for Metz 58 AF 1?
QuoteOriginally posted by wlachan Quote
I'm in the same boat as the OP except that I use a Metz 58 AF 1 dedicated to Pentax. I'm starting to get really exasperated with the inconsistent flash exposures. Is the pTTL problem with the camera or the flash?
10-13-2010, 08:49 PM   #5
Ash
Ash's Avatar
This has been discussed a lot on the forum. P-TTL is far from perfect, it's not even consistent, but it is useable *once* your settings are put right.
I've just come off a wedding myself and realied how much fiddling it does take to get it working as expected, but once I got the result I wanted (after about 3 or 4 test shots) with a wireless setup, then I was set to go from then on. P-TTL managed to give *reasonably* consistent results thereafter. I'm not trying to defend P-TTL, just noting how it's worked for me in the past. Do a search on P-TTL and its inconsistency and you'll be surprised how many threads exist on it.
10-14-2010, 07:35 AM   #6
Weird, mine have been pretty consistent. The only times I've had trouble is shooting with a mirror in front of me, then the flash underexposes like crazy. Another time is when I use multi-light setups in studio with my PTTL flashes. If I don't gobo them just right then flare messes up the exposure and doesn't fire some of the flashes.
I wonder if the exposure settings are what's making the inconsistency problems. I keep mine center-weighted while others might do full evaluative. I figure with evaluative that any change of lighting on the outside fringes of the viewfinder can affect what PTTL does. Just a theory.
I guess I'm trying to "debunk" the whole PTTL thing (knowing full well its not CLS by any means) because I keep thinking of an offshoot of Murphy's Law that says "if everything is working well, watch out...you have obviously overlooked something."
10-14-2010, 09:16 AM   #7
I did many test and found that AF-200FG has very consistence results than the AF-540FGZ and AF-360FGZ. The worst result is from the 540, the 360 is better and 200 is the best.
Perhaps because the 200 is the newest model with some improvement in flash algorithm.
10-14-2010, 10:44 AM   #8
What I have seen:
Certain aspects of a picture can drive any P-TTL flash to underexpose. Namely, any reflective surface that catches the flash.
Also, many AF-540s come from the factory calibrated improperly so that they *consistently* underexpose even with +1 FEC. The discovery of the trimpot under the "FIX->" label at least lets users fix this one. I'm a LOT happier with my 540 since that trimpot was discovered and I tweaked it. Prior to that, it would even underexpose when shooting a frame that was dominated by a matte black object (my shoulder bag from work) and set to +1 FEC.
There's a thread regarding the trimpot somewhere here, don't have the link on hand at the moment.
10-19-2010, 04:52 PM   #9
NeverSatisfied's Avatar
Related Thread
+ 1, Entropy. I think quite a few of the complaints about the 540 underexposing may be related to the trimpot issue. Both my 540's trimpot adjustments were far from optimum.
https://www.pentaxforums.com/forums/pentax-camera-field-accessories/103779-in...x-flashes.html
10-20-2010, 11:53 AM   #10
The problem with p-TTL is not underexposure. It is the inconsistency. This problem is very pronounced with K10D and K20D. With my K10D bodies, I use p-TTL only when it's absolutely necessary.
The K7 (and subsequent models) is much improved. The exposure is more consistent.
p-TTL has the annoying preflash strobe. In general I try to avoid p-TTL when taking photos of people, especially of a group of people.
10-20-2010, 12:24 PM - 1 Like   #11
Ash
Ash's Avatar
Pre-flash exists with almost all new flash systems. It's perhaps the best way of automatically calculating flash intensity required for all types of scenes.
The inconsistency with Pentax is unfortunate but is gradually getting better with each camera. It would be interesting to see how the K-5 fares with the 540 flash in different situations.
On my K20D and K10D, with wireless setup and center-weighted metering, I get decently exposed portraits with P-TTL with FEC at +0.7 on the camera and anywhere between 0 and +1 on the flash. Fill flash, I just keep at FEC 0 on body and 0 on flash for best results most of the time.
11-02-2010, 11:30 AM   #12
I am also trying to learn my AF360 with KX combination. The thing I have noticed about PTTL is that it seems to try and preserve the natural look of the scene, in other words not creating the "bright subject, dark background".
When I first tried this unit, the pre-flash was obvious, but now I don't see it at all. Any suggestions on a good starting point for settings on camera and flash would be appreciated.
11-02-2010, 11:39 AM   #13
QuoteOriginally posted by Bob photo 4 life Quote
In p-TTL, the pre-flash strobe is there. Most people can't tell that there are 2 strobes because they happen very close to each other (about 1/20 sec is my guess) and thus appear as one strobe.
To see the strobes apart, in p-TTL mode, set your camera to 2 sec timer delay. When you hit the shutter release, you will see the pre-flash strobe, then the mirror raising, then 2 second delay, then the shutter release and the main strobe.
11-02-2010, 11:46 AM   #14
Ash
Ash's Avatar
Bob, the post right before yours describes the P-TTL settings that have been working for me for years.
11-02-2010, 12:54 PM   #15
Eruditass's Avatar
Odd, on my K-x, I either get fine exposures or random super overexposed shots.
af-540fgz, camera, change, exposure, results, shots, tripod
Inconsistent Focusing Deiberson Troubleshooting and Beginner Help 20 01-26-2010 02:53 PM
Inconsistent prints Old Film Guy Troubleshooting and Beginner Help 5 08-31-2009 06:56 PM
inconsistent flash results unkabin Flashes, Lighting, and Studio 27 01-26-2009 11:14 AM
inconsistent winder in zx-10 Sluggo Film SLRs and Compact Film Cameras 16 10-03-2008 04:09 AM
Inconsistent results using K10D's built-in flash jarnos Pentax DSLR Discussion 4 12-23-2007 07:22 AM
All times are GMT -7. The time now is 07:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
