10-19-2010, 05:14 PM   #31
Ex Finn.'s Avatar
The M-40 mounts, when new, have a nice, non scratching, plastic film on the underside.
10-19-2010, 05:30 PM   #32
Ex Finn.'s Avatar
QuoteOriginally posted by excanonfd Quote
don't think I would trust my camera and lens to a 1/4"NPT20 bolt that's in the tripod mount
That 1/4-20 UNC is in there pretty tight. No grip and with a light lens it should be fine. Just stay the speed limit.
Unless you are running a really nasty cam..
10-19-2010, 05:49 PM   #33
chalion's Avatar
I never thought i'd see a magnet mount that is tougher than a CB antenna mount.
Edit: Oh, there's another idea.........i'll never use.
10-20-2010, 09:01 AM   #34
Ex Finn.'s Avatar
The M-40 is a K40 CB antenna magnet mount. One in the pic. is just missing the pretty plastic cover.
10-20-2010, 05:21 PM   #35
creampuff's Avatar
These were shot using Manfrotto suction cups. With suction cups you can attach to glass surfaces.
10-20-2010, 05:25 PM   #36
chalion's Avatar
I want it...............whatever those manfrotto suction cups are mounted on.
10-20-2010, 06:42 PM   #37
QuoteOriginally posted by creampuff Quote
Those are great! Was this a rig setup with extension poles and the car moving at a slow pace?
10-20-2010, 09:19 PM   #38
johnmflores's Avatar
I've done some rigged shots but with motorcycles:
My tools of choice have been:
1 - Manfrotto SuperClamp
2 - Manfrotto Magic Arm
3 - Ricoh GX-100
If you can get the SuperClamp to mount somewhere on the car, it won't come off. To build off another suggestion, maybe mount a single Yakima or Thule crossbar to the roof and then mount the SuperClamp to the rack.
FWIW, I found that a good P&S like the Ricoh worked fine in good light. It was much lighter than a dSLR thus easier to mount, went as wide as 19mm (35mm equivalent), and had good DOF and infinity focus so I didn't have to worry about focus issues. As long as the light is good it's a capable setup.
HTH</jmf>
10-21-2010, 08:10 AM   #39
creampuff's Avatar
QuoteOriginally posted by r0ckstarr Quote
Yes. A lot of initial trial and error involved.
10-23-2010, 10:11 AM   #40
ChipB's Avatar
I can't believe no one has mentioned the obvious solution - duct tape - LOTS of duct tape!!
10-24-2010, 10:03 AM   #41
QuoteOriginally posted by ChipB Quote
That's what's holding the car together!
10-26-2010, 03:42 PM   #42
Ex Finn.'s Avatar
And after peeling off the tape, you will not have to worry ever loosing grip on your camera again.
p.s
There is a new and improved thing out there, it is called the "Gorilla tape". This stuff is pretty good. Might even beat a K-40 magnet-mount..
p.s.s
I meant to quote ChipB
10-27-2010, 06:07 AM   #43
falconeye's Avatar
Video rig Cuba style
It's not going to be a serious reply.
But this is what I did in Cuba to make on the road movies when driving through. And below is a video frame capture made with it. Obviously, the people liked it
One must understand that Cuba is very ... short in supply of any kind So, I had to use what I found in my luggage, i.e., my monopod.
The real challenge was to make the camera stay in place despite the gigantic holes Cuba seems to want to sit in their streets
10-27-2010, 07:03 PM   #44
Class A's Avatar
Wow, awesome captures!
Would be cool to see a video snippet. Can't imagine it will look smooth given the cobblestone pavement and the fact that the car isn't a CitroŽn DS.
10-28-2010, 05:22 AM   #45
falconeye's Avatar
I may make a video from it if I find the time. So, I've no plan to release snippets ahead of time.
Yes, it's not very smooth but usable. I may postprocess it with stabilizer software. Problem is that the monopod rattled under more ugly road conditions. And I'm not sure the SR under such adverse conditions didn't actually add shake.
The suction mount would have been great and one should think of a way to further absorb shock between mount and camera.
angles, car, f1000, lines, rig, route, suggestions, tripod
Getting permission to photograph a car at a car show Black Magic Troubleshooting and Beginner Help 16 07-08-2019 07:17 PM
Architecture Falling Facade Dave Wiedemer Photo Critique 1 09-27-2010 10:39 AM
Landscape Falling Waters Jimbo Post Your Photos! 2 03-15-2010 10:42 AM
Falling Leaves bt*ist Monthly Photo Contests 0 10-30-2009 06:48 AM
Some ideas to photograph small venues car shows with your Pentax DSLR ebooks4pentax Pentax DSLR Discussion 10 06-07-2008 07:58 PM
All times are GMT -7. The time now is 12:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
