Originally posted by Digitalis well that is what it appears to be doing, and it is certainly not impossible for it to absorb so much light.
I never said it was impossible for physical objects to absorb or reflect light. I'm saying there's no reason why a good filter would do that. A sheet of cellophane might, of course.
Would you mind describing your comparison procedure? Here's how I would do it:
If you have different filters from different brands, then comparisons are worthless because coatings, glass elements, assembly procedures will be different. If you have filters of the same model from the same brand, then it's possible to compare them (assuming coatings are the same for CP and LP). To do so, it's necessary to identify the polarization axes of both filters (which can or cannot be aligned with the side mark that can or cannot be present). It's reasonable to say that finding the man axes within ±5° is possible, so that should be the uncertainty we base ourselves on (though I'd have to calculate how much ±5° would affect polarization, that's far from linear).
Once the filters are well characterized, it should be possible to measure their exposures readout when spot focusing on a static subject if the light souce does not vary.
Then, all that's left to do is to try to factor in the thickness of the filters (which will affect the direction of transmitted light) and the distance between the back surface of the filters and the front of the lens. Then it could be possible to evaluate, within a significant uncertainty value, the performance of each filter.
Or we could try to find the spec sheets of the filters, look at their light transmission specs, and trust the manufacturer. But I'm betting both filters will have ">97% light transmission" as their specs, if they are of the same brand and model.
Long story short, there are many, many variables that can affect polarization but which do not relate to the actual transmission of the filters. And if they are different models, it gets worse
I'm re-reading my text before clicking "Post" and I want to stress out something : I hope this does not sound arrogant in any way. That's not at all my intent. My objective is to make sure we stand on the same ground when when discussing optical performances. I'm a scientist completing a PhD in optics and that makes me methodical. I'm not trying to be "right", or "wrong", only accurate.
Good day.
