Originally posted by rgibbons
I recommend you DON'T buy a fish eye adapter.
I purchased 3 of these, include large expensive ones. They are all blurry around the edges (the place you buy a fish eye to see), and suffer from severe Chromatic aberration. They really only give somewhat sharp pictures at F22.
The Adapters aren't too bad for poor resolution video cameras, and are not bad at turning a normal lens into a wide angle lens. But they are poor at turning a wide angle into an ultra wide fish eye.
If you can't afford a real fish-eye, you might have better results taking several pictures and stitching them together with free software on your computer.
I eventually bought a real 180 degree view lens, and it is a pleasure to work with.
I got the Pro-Optic from Adormama (with "A" setting for Pentax), It is also sold as a Bowers at B&H, and under several other brands, all made by Samyang. It actually has less distortion (better projection in my opinion) than a fish eye (which expands the center, and compresses the edges more).
Ultra wide lenses are great fun, and useful for recording a wide field. I've also used this for 360 panoramas (stitched together on my computer).
It takes a while to get used to envisioning what a scene will look like, before you look through the camera, my brain wasn't used to seeing my feet at the same time as the tree branches overhead.
+1 on this.
I also have the 8mm Pro-Optic and it is a great lens. All there is is a minor amount of CA (about 1 pixel width on my K10D) if you feel inclined to go looking for it.
As I posted above, the issue is that these are really only good for P&S cameras. I have had no issue there but the P&S is only 36mm focal length equivelent to start, putting this on a 24mm to get really wide is a disappointment. I have even played with different distances from the prime lens, and this did not help.\
